![]() "Ron Natalie" wrote in message ... Jim Martin wrote: Hi Folks, Just picked up a '56 172 which I plan to restore up here in Canada. I'm missing cowlings and log books. Is there someone I can talk to at FAA to see if AD's have been complied with on this aircraft. Generally the FAA has no clue if an AD is complied with. There's no paperwork that gets filed, it's only recorded in the aircraft logbooks. Since you now own it, you need to do an ad search to day one, a weight and balance, create an equipment list and do the logs lost, new logbook estimated time XXX thing. Good luck and I hope your "suprises" are small and inexpensive...... |
Thanks for the input guys, it seems to be pretty much all there and it's
very low time { been sitting in a field for 15 yrs} and it's pretty grungy. I'm sure I'll have some surprises It'll be a several year project. "pbc76049" wrote in message ... "Ron Natalie" wrote in message ... Jim Martin wrote: Hi Folks, Just picked up a '56 172 which I plan to restore up here in Canada. I'm missing cowlings and log books. Is there someone I can talk to at FAA to see if AD's have been complied with on this aircraft. Generally the FAA has no clue if an AD is complied with. There's no paperwork that gets filed, it's only recorded in the aircraft logbooks. Since you now own it, you need to do an ad search to day one, a weight and balance, create an equipment list and do the logs lost, new logbook estimated time XXX thing. Good luck and I hope your "suprises" are small and inexpensive...... |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
