![]() wrote in message oups.com... The Wortmann FX-67-K-170 airfoil that the PIK-20 and Nimbus 2 use is very sensitive to bugs, and even a very small amount of rain. With a waxed wing surface the rain drops tend to stand tall, severely separation the top surface air flow. Leaving the wings sanded and unwaxed allows the rain drops to flow more smoothly on the wing surface; significantly reducing drag. However, only a bug wiper system appear to help the bug problem. I sand the wings on my Nimbus 2 and they seem to deliver the advertised L/D. I have tried surfactant on a few gliders and, by appearance only, it seems to work. A capful or two of dishwasher "rinse clear" or "spot free" or something like that in a bucket of water seems to be enough. As for the bugs, as slow as I fly, they have time to get out of the way. Bill Daniels |
What grit do you use on the Nimbus 2 do you sand top and bottom and how far
back?? "Bill Daniels" wrote in message ... wrote in message oups.com... The Wortmann FX-67-K-170 airfoil that the PIK-20 and Nimbus 2 use is very sensitive to bugs, and even a very small amount of rain. With a waxed wing surface the rain drops tend to stand tall, severely separation the top surface air flow. Leaving the wings sanded and unwaxed allows the rain drops to flow more smoothly on the wing surface; significantly reducing drag. However, only a bug wiper system appear to help the bug problem. I sand the wings on my Nimbus 2 and they seem to deliver the advertised L/D. I have tried surfactant on a few gliders and, by appearance only, it seems to work. A capful or two of dishwasher "rinse clear" or "spot free" or something like that in a bucket of water seems to be enough. As for the bugs, as slow as I fly, they have time to get out of the way. Bill Daniels |
I use 400 grit up through 1200 grit and sand all the way to the trailing
edge top and bottom using a 20mm thick bar of super flat Plexiglas as a sanding block. I'm battling aging and cracked gelcoat that must be replaced someday. I've used matching white lacquer primer to stabilize the old gelcoat and provide a good sanding base. The Lacquer primer also replaces the gelcoat lost to sanding. The whole prime and sand operation takes about a day and I only have to do it once a year in the spring. So far, it seems to be a good solution for an old glider. Maybe it's the condition of the wing but I don't see much degradation in rain or with modest bug buildups. If you are interested, I uploaded a flight to the OLC for September 2nd - you can download the IGC file and analyze the performance for yourself. The wing got wet a couple of times in that flight. Bill Daniels "culverflyer" wrote in message ... What grit do you use on the Nimbus 2 do you sand top and bottom and how far back?? "Bill Daniels" wrote in message ... wrote in message oups.com... The Wortmann FX-67-K-170 airfoil that the PIK-20 and Nimbus 2 use is very sensitive to bugs, and even a very small amount of rain. With a waxed wing surface the rain drops tend to stand tall, severely separation the top surface air flow. Leaving the wings sanded and unwaxed allows the rain drops to flow more smoothly on the wing surface; significantly reducing drag. However, only a bug wiper system appear to help the bug problem. I sand the wings on my Nimbus 2 and they seem to deliver the advertised L/D. I have tried surfactant on a few gliders and, by appearance only, it seems to work. A capful or two of dishwasher "rinse clear" or "spot free" or something like that in a bucket of water seems to be enough. As for the bugs, as slow as I fly, they have time to get out of the way. Bill Daniels |
My experience from 6 years racing the PIK agrees with Bill's. Sand
with 600 at 45 degrees back to high point of airfoil. Clean with water with generous helping of dish soap. Wipe dry, don't rinse. Other very important factor in climb of PIK is flap setting. It wants to fly at a constant AOA with additional lift for tighter turns added by flap setting. As I recall, I used 6 deg for 30 deg of bank, 8 deg at 45 and changes flap setting whenever bank changed, even recentering. A lot of work, but it did help performance. Good Luck UH |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
