I take it from your question that your PIK-20 is not climbing well.
When I first began flying this type, I was disappointed with the climb until I discovered top rudder. If your yaw string is out on the forward canopy and while circling is in line with the longitudinal axis, you are in a slight skid. There is some controversy about the magnitude of the skid and this subject is covered very well by Richard Johnson in the October 2004 issue of Soaring Magazine. The climb performance of my PIK-20B improves a lot when I apply top rudder. When the climb is optimum, the yaw string is displaced about 5-10 degrees toward the outside of the turn. This seems to be a trait of most gliders that I have flown but my PIK-20 seemed especially sensitive in this regard. So before you begin sanding or polishing, you might try this first...if you haven't already. Paul ZZ "culverflyer" wrote in message ... Sanding rather than waxing a PIK 20 Question Has anyone have info on this I was told that when this persons PIK did not clime well he would sand the wings with 400 grit . |
Hello Paul et all,
I also aggree with this. However it appears to work under certain conditions of lower bank perhaps. At higher bank turns I found no real big difference. The one thing is assured with the "B" model is that it climbs really well in small lift. This came also from a more experienced pilot who tried my "74". Again, I would be quite relinquant to modify the profile of the wing with sanding unless definite deformation near the spar. Cheers Marc "74" "P. Corbett" a écrit dans le message de news: .. . I take it from your question that your PIK-20 is not climbing well. When I first began flying this type, I was disappointed with the climb until I discovered top rudder. If your yaw string is out on the forward canopy and while circling is in line with the longitudinal axis, you are in a slight skid. There is some controversy about the magnitude of the skid and this subject is covered very well by Richard Johnson in the October 2004 issue of Soaring Magazine. The climb performance of my PIK-20B improves a lot when I apply top rudder. When the climb is optimum, the yaw string is displaced about 5-10 degrees toward the outside of the turn. This seems to be a trait of most gliders that I have flown but my PIK-20 seemed especially sensitive in this regard. So before you begin sanding or polishing, you might try this first...if you haven't already. Paul ZZ "culverflyer" wrote in message ... Sanding rather than waxing a PIK 20 Question Has anyone have info on this I was told that when this persons PIK did not clime well he would sand the wings with 400 grit . |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
