On-Condition wrote:
Most gas radials I've seen/flown had around 8:1 compression, that's food for thought. Just wondering though, are the german aircooled diesel cylinders intergral with the block? the WWII era Guiberson and Cat D-200A Radials had 14.3:1 and 15.5:1 respectively. The Guiberson weighed about 1100 pounds in Tank trim, And that Cat engine started out as an Wright R-1820, but weighed over 3000 pounds by time Cat beefed it up enough to be reliable. ** mike ** |
mike wrote:
On-Condition wrote: Most gas radials I've seen/flown had around 8:1 compression, that's food for thought. Just wondering though, are the german aircooled diesel cylinders intergral with the block? the WWII era Guiberson and Cat D-200A Radials had 14.3:1 and 15.5:1 respectively. The Guiberson weighed about 1100 pounds in Tank trim, And that Cat engine started out as an Wright R-1820, but weighed over 3000 pounds by time Cat beefed it up enough to be reliable. Diesels are heavy, I know. Just got my tractor up to about 35mph on the runway, but the damned thing wouldn't stay in the air. (2-stroke) aircooled diesel radials: 70 hp 121 lbs 150 hp 185 lbs 300 hp 271 lbs http://www.zoche.de/specs.html |
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
2-stroke diesel is the (near) future? | Max Kallio | Rotorcraft | 123 | July 18th 05 12:39 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Owning | 1 | January 4th 04 04:04 AM |
