The limiting airspeed, Vne is the speed where the airplane structure still
meets the certification requirements. For light aircraft it is normally set at 90% of Vd (demonstrated dive speed) The limit could be where the maximium design gust equals the structural limit of the airplane or it could be the highest speed where a reasonable flutter margin is present. As others have said, it could be related to critical Mach number although this is unlikely to be the limiting factor for slow, light airplanes. If the limit is for gust loading, then it is based on CAS. If it is based on flutter or Mach limit, it is based on TAS. Even if it is based on TAS, it is given in IAS in airplanes without a Mach meter. or barber pole. The IAS limit is based on the ceiling of the aircraft.. The same thing can be accomplished by placards (reduce Vmo (or Vne) by x knots for every thousand feet above xx,xxx' altitude. The "coffin corner" is where stall and Mmo (not Vne) come together. I don't think that there is an aiplane that can reach the coffin corner that even has a Vne. There is some discussion of this topic in one of Barry Schiff's books. Mike "private" wrote in message news:6FOUe.465897$s54.126911@pd7tw2no... Hello Todd, In a recent thread on R.A..S.(interesting question about stall and airspeed) that morphed into a discussion about coffin corner, Todd explained, "Flutter limits high true airspeed operations, and it is possible to get to the coffin corner where stall speed and Vne approach each other." and Jim suggested we "consider Vne as a TAS". Can I have the groups wisdom and further explanation of the reasons for this and of how Vne changes with altitude. Should we be doing preflight calculations of Vne IAS reductions when planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Thanks in advance |
Mike Rapoport wrote:
I don't think that there is an aiplane that can reach the coffin corner that even has a Vne. Airplanes probably not. Aircraft, yes. Stefan |
Which ones?
Mike MU-2 "Stefan" wrote in message ... Mike Rapoport wrote: I don't think that there is an aiplane that can reach the coffin corner that even has a Vne. Airplanes probably not. Aircraft, yes. Stefan |
Which ones? I had thought of some older gliders which have pretty low Vne. After I had hit the send button, it dawned to me that they also have a pretty low stall speed, though... Stefan |
![]() "Stefan" wrote in message ... Mike Rapoport wrote: Which ones? I had thought of some older gliders which have pretty low Vne. After I had hit the send button, it dawned to me that they also have a pretty low stall speed, though... Stefan I was thinking of sailplanes too. Hard to imagine a sailplane with a critical Mach number equating to a IAS of 45kts or so even at FL500. The key to this issue (IMHO) of Vne is that it may be based on any one of a number of limiting factors, some of which are related to CAS and some to TAS. The airplanes where Mach number is an issue (that I am familiar with) have a Vmo and Mmo but don't use a Vne. Mike MU-2 |
