seaplane motoglider?
Old September 13th 05, 03:47 AM
John Ammeter
What's the defination of a motorglider?
John
Morgans wrote:
OK, here's a question. Does a seaplane motoglider exist?
If someone were to make one, would it be eligible to be flown as a
motoglider, and therefore be able to have a pilot (without a medical) fly it
legally as a motoglider?
And yes, I did Google, first. g
Old September 13th 05, 04:04 AM
UltraJohn
John
My GUESS would be any airplane that is designed to be taken off under power
and intentionally powered down. Oh and yes, most important, registered that
way!
I supposed you could built a 747 look alike (remember the post about the 747
plans?) and register it as a glider (with what about a 5 to 1 glide
ratio!). Now that would be interesting!
John
Old September 13th 05, 04:37 AM
Dick Schreder started a self-launched seaplane glider project back in the
1970s. I believe he was going to call it a HP-21. The project was never
finished and was donated to Penn State University (PSU) prior to his death.
The HP-21 was to be a two-place, side-by-side, self-launching, amphibious
sailplane with automatic extending and retracting engine. Design specs
called for a foam and fiberglass hull, retractable gear and wings
constructed of metal and foam (like the HP-16, RS-15 and HP-18).
Dick flew seaplanes in WW-II and was the first sinking of a U-Boat by a US
aircraft. (It is a great story. It and others can be found in the book
"10,000 Feet and Climbing - The Aviation Adventures of Richard E Schreder.)
The HP-21 was going to be an attempt to combine his love of soaring with his
love of "flying boats."
The PSU Soaring Club has what remains of the project listed in the "Trading
Post" section of http://www.soaridaho.com/Schreder.
An article about the HP-21 appeared in "Soaring" many years ago. I have a
copy and will posted on the "Schreder Designs" web site when time is
available.
HP-14 N990 "6F"
"Morgans" wrote in message
it
Jim in NC
Old September 13th 05, 04:38 AM
Morgans
Default seaplane motoglider?
Jim in NC
Old September 13th 05, 05:41 AM
Morgans
available.
Thanks. When you do, give a shout back here, if you have the time?
Jim in NC
Old September 13th 05, 05:44 AM
Morgans
"John Ammeter" wrote in message
There are some pretty strict definitions, as I recall, having to do with
weight to area, or span, and glide performance, IIRC. I'll try to see what
I can find.
Jim in NC
Old September 13th 05, 06:48 AM
Chris W
I bet it would have a LOT better glide ration than that! I seem to
remember a story about some airliner that ran out of fuel due to a mix
up with metric vs English units, I think they had a malfunctioning fuel
computer which made it necessary to do the calculations manually.
Anyway, if I remember right, it glided around 85 miles from an altitude
of 35,000 ft. If it landed at sea level, which I doubt, the glide ratio
was nearly 13 to 1.
Chris W
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
http://thewishzone.com
Old September 13th 05, 08:39 AM
Morgans
what
I can find.
After more than an hour of searching, I found the motor glider specs he
http://www.sonex-ltd.com/motorglider_definition.html
It could glide like a dog, but it has to carry no more than two, not exceed
1874 pounds, and the maximum weight to wing span squared can not exceed .62
lb. / ft squared.
So that means that at maximum weight, you would need a wingspan of about 55
feet.
Doable? I think so. For a seaplane, or amphibian, it would have to have
some type of pontoons or floats on the tips, or it would hit the tips, on
the slightest bit of rocking. Not a problem.
How about the rating needed? For a powered glider, a glider rating, with an
endorsement for self launch, I think, is all you need. What about launching
from water? More endorsements, or is there one for water to add to glider?
Would you have to have a single engine fixed wing land/seaplane?
One thing I can say, is that I have never seen _this_ question here, (or
anywhere) before! g
Jim in NC
Old September 13th 05, 05:05 PM
Drew Dalgleish
feet.
Jim in NC
gee that'd be fun to dock ; (
Old September 13th 05, 06:04 PM
"T o d d P a t t i s t" wrote in message
he
exceed
..62
lb. / ft squared.
These limits were adopted to prevent people from registering
everything under the sun as a glider. :-) I've seen some
designs with removable wingtips, allegedly for hangaring
ease, but which made it far more like a typical airplane
than a glider if flown with the tips off. I have no idea if
they'd get the design actually registered as a glider.
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
If my memory serves me correctly, the above requirement of wingspan ^2
divided by gross wt not to exceed 0.62 lbs is stated in the "Certification"
limitations. It has been argued that this requirement doesn't apply to
experimental air craft. If it did, "Space Ship One" would not be registered
with the FAA as a glider. On the other side of the coin, the Windrose meets
the requirement; however, you find cases where it has been registered as an
"airplane". Communications with the owners revealed that this was done to
avoid having to spend the time and money to get a glider rating.
HP-14 N990 "6F"
Seaplane Rating Add-On and Seaplane Rental Peter Bauer Piloting 10 May 29th 05 11:53 AM
American Lake SPB Closing C J Campbell Piloting 23 December 27th 04 03:26 PM
Restored military seaplane ready for surfing duty Otis Willie Naval Aviation 0 December 15th 04 10:28 PM
Flew a seaplane Michael 182 Piloting 17 August 26th 04 01:52 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
