On Tue, 13 Sep 2005 16:17:02 GMT, Kyler Laird
wrote in :: Larry Dighera writes: A motor in the hub design is the most elegant solution. I wouldn't have thought the motor would have sufficient torque to drive the wheels without adequate gear reduction. Exactly - the much higher than usual (5x) low-speed torque of the Chorus motors are what make them so appropriate for this application. I wish I had a kit for my Aztec! Even at 5X torque, it would seem that some gearing would be necessary for a small motor to move an airliner. But there may be a way to build that into the hub also. I got interested in BOREF for their licensing of Cool Chips http://www.coolchips.gi/ to keep avionics and turbine engines(!) cool. I think that's going to take awhile to develop. The motors are much more immediately exciting. --kyler Wow! That is a breakthrough. Thanks for the information. |
On 2005-09-13, Larry Dighera wrote:
Even at 5X torque, it would seem that some gearing would be necessary for a small motor to move an airliner. But there may be a way to build that into the hub also. Probably a planetary gear set. The motor's casing (if the armature is held still and the case allowed to rotate) could form the sun gear. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Even at 5X torque, it would seem that some gearing would be necessary for a small motor to move an airliner. But there may be a way to build that into the hub also. http://www.wallstreetcorner.com/stockpick.html I signed a non-disclosure agreement, & was therefore able to view actual tests on the product -- all I can say is that it is amazing. The WheelTug(TM) drive can fit within the existing nose wheel hub of a 767-class aircraft, with the goal of largely eliminating the use of tow tugs & jet engines in moving aircraft on the ground. [...] An economic analysis by WheelTug plc estimates that a typical WheelTug System would have a net present value to airlines of over $6 million per airplane Yeow! --kyler |
![]() Looks to be very encouraging despite the acknowledgement on the site that they still have some engineering hurtles to overcome. When they get a flight ready test package put together I'll be real curious as to how they do the final integration and structural installation, as well as powering it. Craig C. |
![]() wrote in message ......I'll be real curious as to how they do the final integration and structural installation, as well as powering it. Power it from the onboard APU. |
![]() John Gaquin wrote: wrote in message ......I'll be real curious as to how they do the final integration and structural installation, as well as powering it. Power it from the onboard APU. Yeah, that much I had figured out....what I was meaning is, are the drives going to be run off of some high voltage AC or DC or run from already common 28 VDC or 115/400 3p that the APUs can already develope. |
On Tue, 06 Dec 2005 22:17:02 GMT, Kyler Laird
wrote in :: An economic analysis by WheelTug plc estimates that a typical WheelTug System would have a net present value to airlines of over $6 million per airplane Yeow! Thanks for the updated information. In the last year CHOMF has been selling between $5 and $20, and is currently $7/share. It looks like a good investment to me. |
Is a Turn Coordinator an electric motor or powered by fan? | kickinwing | Piloting | 5 | June 11th 05 12:25 PM |
Cherokee Electric Pitch Trim | Jonathan Goodish | Owning | 4 | November 18th 04 02:43 AM |
Piper Arrow electric fuel-pump | MC | General Aviation | 7 | June 3rd 04 02:50 AM |
taxi in reverse? | Malcolm Teas | Home Built | 10 | February 21st 04 12:26 AM |
More on the electric verses turbojet | cdubya | Soaring | 8 | September 25th 03 09:16 AM |
