![]() "Maule Driver" wrote in message news ![]() Udo Rumpf wrote: I am always surprised when I read comments about sensitivity to rain or water and I agree water that pearls on the wing surface will have a negative effect on "all airfoil shapes". When was the last time you flew through rain and where it mattered in regards to getting home or not. Either one is cut off and one has to land in any case or one escapes a light and short duration shower and waits it out. I have no interest in how my airfoil performs when exposed to water. In my limited experience, you are generally correct. But the PIK20b in my experience is *particularly* sensitive to water. I flew the PIK in a number of eastern US contests. We didn't fly in much rain but one particular encounter in the mid-80s captured my attention. I pulled up into a thermal just as a light sprinkle of rain hit. I stalled out of the pull up! This is the only time I can remember stalling accidently in any conditions. It didn't at first occur to me that the rain and the stall were related but it soon became apparent that I wasn't flying the same sailplane I was flying before the rain. I didn't make it home that day and landed at an airport. The anemic Citabria was sent from Dansville to pick me up at Grand Canyon airport (NY State). We started the tow just as another light sprinkle fell. The Citabria lifted off in its normally anemic way but I couldn't get the unballasted PIK off the ground. I rolled off into the grass at the end. Anyone familiar with Grand Canyon (in the mid-80s) knows the reason for the name. Fortunately the ground falls away quickly and I became airborne. I would suggest that the PIK is a notable exception to your conclusion. On hind sight I should have realized how bad "moisture" is on the FX 67 airfoil I had done experiments with this airfoil under the assumption that it was only related the way it was constructed, as in the HP technique, I used turbulators successfully on the top surface to counter some of the ills of that airfoil. Wing dropping on take off for one, as well as in landing mode when the glider with this airfoil showed stall behaviour well before the stall speed was reached. One other experiment I conducted, installing a .040" wire, tape down along the span about 5% from the leading edge. My surprise was It climbed much better but the cruise was no better then a K6 which made sense to me. It seems everything has be just dead on with this airfoil shape for it to perform to it potential. One glider I know of is the LS3, which has done just that I never heard of any complains. Regards Udo |
![]() Udo Rumpf wrote: "Maule Driver" wrote in message (snips) I would suggest that the PIK is a notable exception to your conclusion. It seems everything has be just dead on with this airfoil shape for it to perform to it potential. That seems to be what Dick Johnson confirmed with his PIK improvement work back in the 70s or early 80s. One glider I know of is the LS3, which has done just that I never heard of any complains. I didn't know it had the same airfoil but I never heard complaints either. Thanks Bill Watson (MauleDriver) |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
