relative climb performance
Old September 14th 05, 06:12 PM
Default relative climb performance
Q. All the gliders below join the same thermal at
2000 feet. In which order will they reach 5000 feet.
Discuss.
LS7
Discus
ASW19
DG300
Libelle
ASW20
LS6
John
Old September 14th 05, 06:36 PM
Lars Peder Hansen
Depends a lot on the nature of the thermal. Weak, crummy, narrow and
turbolent ones favor some gliders while strong, wide & steady ones favor
other types. -And then, of course, it depends on the wing loading, some
types are good climbers at other wing loading ranges than others.
- Actually, the above is just useless theory. In the real World, the Libelle
always climbs better than anything you can throw at it ;-)
/Lars Peder
Discuss.
LS7
Discus
ASW19
DG300
Libelle
ASW20
LS6
John
Old September 14th 05, 07:32 PM
Andy
To have any meaningful discussion you'll need to specify the wing
loading, the thermal strength, and the characteristics of the thermal
(big, smooth, small, turbulent etc.).
Without that input I'd assume that the glider with the lowest wing
loading and slowest stall speed will win. Is that the Libelle?
On the other hand I often outclimbed lighter loaded Libelles with my
ASW 19. In tight and/or broken thermals pilot technique can override
the differences in gliders.
Andy
Old September 14th 05, 08:28 PM
OK, assume standard British 2 knot thermals. Gliders
have no water in. Thermals are small but smooth.
Reason for the question....I can get L info off the
net, but not climb data...
John
the wing
of the thermal
the lowest wing
the Libelle?
Libelles with my
can override
Andy
Old September 14th 05, 08:45 PM
Bob Kuykendall
The one being flown by the pilot who considers it "their thermal."
Old September 14th 05, 09:01 PM
Andy
Minimum sink speed and minimum sink rate should provide some clues.
That data should be available. The stronger the thermal the more pilot
technique overrides small difference in glider sink. In large weak
thermals almost nothing will prevent the lower sink rate glider
climbing better and topping out higher. That effect is obvous, and
frustrating to the low pilot, at contest pre-start gaggles when the max
start height is greater than top of lift.
Andy
Old September 17th 05, 07:04 PM
to have a REALLY meaningful discussion you should have added a pilot
name next to each ship.
BJS
Old September 17th 05, 07:21 PM
Thanks Eric !
But I've switched brands...
Who does flight plans? Michael 182 Piloting 158 July 4th 05 02:50 AM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
172 N Climb Performance Roger Long Piloting 6 September 10th 03 11:18 PM
