![]() "T o d d P a t t i s t" wrote in message news ![]() "private" wrote: with altitude changes, but also other dynamic "q" factors on the airframe at higher "effective" airspeeds. Thank you for the informative reply. Please define "q" Q is the term aerodynamicists use to refer to "dynamic pressure." Dynamic pressure is equal to 1/2 x rho x V**2. It's the pressure your airspeed reads - the difference between pitot pressure and static pressure. It's a pressure solely due to airspeed. If you listen to a space shuttle launch you will hear a reference to "max-q." That's the point of max aerodynamic stress on the shuttle. As the shuttle accelerates, airspeed increases, which increases q, but as it climbs, rho (air density) decreases, which decreases q. After max-q the decreasing air density decreases q faster than the increasing speed increases it. thanx, I should have remembered that, but then I would not have learned about "max q" Happy landings |
