Larry Dighera wrote:
but the issue is with uncommanded roll as a consequence of turbulence. If the aircraft is not maneuvering (or even if it were), the electronically augmented control system would detect an incipient wing displacement before a human could detect it, and issue the appropriate control input to counter it. These commands would occur so rapidly as to be virtually undetectable by the occupants. Most contemporary transport aircraft have gust alleviation systems (not so much for ride comfort than to reduce structural loads); the B-2 has a similar system. The systems have only limited ability to counter roll but it's not for want of trying -- it's sort of entertaining looking out and watching twitchy spoilers trying to keep the wings level -- or the wingtips from trying to touch. Actuator response times, interactions with the stability of the design and the possibility that the roll rate induced by gust could exceed the roll rate of the aircraft place limits on the magic that you can perform. It's not to say that you can't come close. Think of the electronic suspension systems available on some of today's automobiles*. They are capable of providing a smooth ride over the roughest of roads by sensing body dip, and immediately extending the suspension to prevent further excursions. These corrections happen in milliseconds; it verges on magic. Yet more technology grafted on from Lotus. I was never quite understood why they never commercialized that technology -- save for the fact that it sucked power and had really bad failure modes. Unless you're suggesting that fly by wire could automatically limit the roll rate to limit the acceleration felt by outboard passengers I'm unclear how it would address the problem. I'm confident that an electronic control system could dampen all but the most severe turbulence induced excursions, in addition to seeing that the commanded roll rate was strictly met. That's sort of my point. Unless you limit commanded roll rate to something small you haven't done anything to address the problem of G (un)loading for the outboard passengers, and setting the roll rate limit low creates its own class of problems. There's also the roller coaster effect -- being on the high side and looking down the width of the cabin at what seems like an exaggerated angle -- but I suppose one could deal with that with dividers of some sort. Exactly. First class would be along the longitudinal axis with coach toward the wing tips with obscure partitions separating them. Yeah, that's the notion I was after. There's also the issue of just how one evacuates such an aircraft. Umm... Crashworthyness would be an issue less amenable to resolution than evacuation. Both would be -um- problematic. In the event of an in flight electrical failure disabling the electronic control augmentation, it could get "interesting." What does Airbus use to overcome that issue? They don't. Everything is inputs to the redundant autopilot system; stick and throttle are suggestions, not really commands. Raise your hand if you've had to sit on the ramp while they do a complete engine shut down in order to reboot an A320 series aircraft prior to departure (it's happened to me twice). Of course I'm not too thrilled with the idea of riding in an A380, either. Right. In the event of a 800+ passenger stampede, one would likely be trampled before he could clear the aircraft. :-) That's assuming that you weren't in the middle of a refreshing mud bath with cucumber slices on your eyes (if you believe for a moment the claims of Airbus and Branson that A380s will have such amenities as opposed to high density seating). |
"Chris Kennedy" wrote in message
They don't. Everything is inputs to the redundant autopilot system; stick and throttle are suggestions, not really commands. This true when operating in normal law mode (99% of the time). However, when degraded to direct law mode, the A-320 operates like a normal airplane. The reboot is not because it can't fly, but because we like everything to work so as to provide the safest flight we can (and we are lazy and don't want to handfly a whole leg). D. (it tunes it's own VORs) |
High-tech gizmos propel aviation into the future | Omega | Piloting | 3 | June 11th 05 06:48 AM |
Laser beams being aimed at airliners? | Corky Scott | Piloting | 101 | January 22nd 05 08:55 AM |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Any planes remotely quiet? | Chris Hoffmann | Owning | 3 | July 27th 03 06:13 AM |
