Do you ever use standby on your transponder?
Old September 15th 05, 06:15 PM
Maule Driver
Default Do you ever use standby on your transponder?
I don't. It stays on 24/7 (you know what I mean). 1200 unless given a
code. It effectively prevents "Maule, check your transponder" unless
using the wrong code.
I make no attempt to turn it off or go to standby while taxiing or
anything else. I've never been asked to go to standby or otherwise
questioned.
This has been discussed before but I'd suggest the everyone can do this
without causing a problem for anyone.
Old September 15th 05, 06:20 PM
Larry Dighera
On Thu, 15 Sep 2005 17:15:14 GMT, Maule Driver
wrote in
I don't.
I was taught to switch from standby upon starting to roll down the
runway for departure. The reasoning that was cited had to do with
radar clutter on the airport surface.
ADS-B may change this practice, however.
Old September 15th 05, 06:22 PM
Peter R.
I have the Garmin 330 with traffic uplink. I sometimes have to switch it
to STBY just after landing to prevent hearing several traffic alerts caused
by taxiing traffic.
Granted this transponder does have an automatic STBY/ON and visa-versa
switching ability, but upon landing it does not seem to switch quickly
enough to prevent the erroneous traffic alerts.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old September 15th 05, 07:30 PM
Orval Fairbairn
questioned.
I set to "Standby" on the ground, to prevent reflections that could
damage the unit.
I also set "Standby" if I am a wingman in a formation (Only Lead
squawks).
Old September 15th 05, 07:48 PM
Robert M. Gary
I think that is a myth. I don't think the computer shows ATC your
signal if your altitude shows you at ground level.
Robert M. Gary
Its useful when flying in a flight of two. ATC will ask you to turn it
to standby.
-Robert
Old September 15th 05, 08:07 PM
Orval Fairbairn wrote:
[snip]
damage the unit.
A perhaps ignorant question: What reflects that could damage the unit
and how could it damage the unit?
John
Solo Student
Old September 15th 05, 08:24 PM
Mortimer Schnerd, RN
Ditto.
VE
Old September 15th 05, 08:25 PM
Thomas Borchert
Maule,
On the ground and off the runway mine is on standby. BTW, our GTX330
now handles that automatically (mostly) in conjunction with groundspeed
from the GPS.
Thomas Borchert (EDDH)
Thomas Borchert
Peter,
You can adjust that. There is a timeout after which it will go to GND
mode after the speed falls below the threshold speed (30 knots is
default, I think). The default delay is 30 seconds, I think, giving you
time to taxi off the runway. But you can set that to zero. Google for
the 330 set-up manual if you don't have it.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Transponder petition Ian Cant Soaring 11 February 28th 04 06:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
