Skyhawk versus Archer?
Old September 16th 05, 02:25 AM
Jay Honeck
Of course I fly an Archer II and it serves my mission really well which
often have all 4 seats filled with flight legs of 2 to 3 hours.
Flight plan for 110 Knots, lean it well and cruise at about 2450 RPM to
use about 9.0 to 9.5 GPH.
Agreed, the Piper Archer is a great aircraft. It does everything okay, and
nothing terrible -- which is about as good as it gets in a Spam Can. And
it will out-perform a standard Skyhawk in every measure. (Of course, with
20 or 30 extra horsepower, it's not really a fair comparison. You really
should be comparing it with the Skyhawk XP...)
If you buy an Archer, don't forget to join the Cherokee Pilots Association.
See them at http://www.piperowner.com/ Don't let the amateurish website
fool you. Their on-line "Cherokee Chat" offers an unbelievable wealth of
Cherokee knowledge that you won't find anywhere else.
Now if you *really* want the ultimate Cherokee, find yourself a Pathfinder
or a Dakota.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 16th 05, 02:55 AM
Roy Smith
In article EapWe.332775$_o.8703@attbi_s71,
Of course, keep in mind that the Archer will burn more fuel than the 172.
I flight plan the Archer at 8.5 GPH (and 2350 RPM). The 172 burns more
like 7 GPH. With the price of fuel these days, that's a good $5/hr cheaper
to operate.
But the bottom line is both the 172 and the Archer are good, simple,
reliable airplanes. Nothing outstanding from either in the way of
performance, but cheap to operate (by aviation standards), and any mechanic
anywhere will be familiar with working on them.
Old September 16th 05, 01:35 PM
: Of course, keep in mind that the Archer will burn more fuel than the 172.
: I flight plan the Archer at 8.5 GPH (and 2350 RPM). The 172 burns more
: like 7 GPH. With the price of fuel these days, that's a good $5/hr cheaper
: to operate.
... only if you cruise it at 75%. If you cruise at the same absolute hp (e.g.
65% on a 180 vs. 75% on a 160), they burn the same. Approx 8-8.5 gph. I doubt a 172
with 150/160hp at 75% only burns 7 gph unless you're only running 60%... you need
fuel to make power.
That said, the Skyhawk vs. Archer has pretty much been beat to death.
Ignoring high/low wing debates, and the single-door that's already been mentioned,
they tend to fly about the same. Not sporty by any stretch, but not overly heavy
either. The biggest difference is in the sink/stall characteristics. The hershey-bar
cherokees (e.g. the Archer I as explained previously) has a very benign stall. They
also have a fairly high sink rate by comparison to a 172. I'm not so sure about the
taper-wing variety... I think they're somewhere in the middle.
Skyhawks carry a $5-10k premium over equivalent Cherokees. Most likely due to
"everyone" training in a Cessna. My feelings were Pipers give more bang for the buck.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old September 16th 05, 04:32 PM
Jonathan Goodish wrote:
: Agree, but in this debate there is one very significant difference: the
: extra 20hp. In my opinion, the 160hp C172 is underpowered unless you
: plan to be a solo flyer.
I did say *comparable* aircraft. That would be a 150hp C172 vs. PA-28-140.
More bang for the buck in the Piper. There aren't too many 180hp C172's that are the
same age as most of the Archers, so it's not really a fair comparison. In the lower
HP range, though, (150 or 160) the Cessna brings $5-10K more than a comparable Piper.
As someone who trained in an 145hp O-300, I can't say I'd agree with the last
bit either. In fact, the older 172's tend to perform better on less engine because
they're not weighted down with extra radios, other equipment, and sound treatment.
The straight-tails in particular have good performance.
-Cory
* Cory Papenfuss *
Old September 17th 05, 08:55 PM
Andrew Gideon
extra 20hp.
Numerous older skyhawks have been converted to 180hp. I just helped my club
buy one, and there were plenty on the market (although they were the
minority, admittedly).
Most still had fixed pitch props, but I did find one example that had been
upgraded to a constant speed prop. Amusingly, while I'd never heard of
that done before on a 172, the owner of that plane had never heard of a
180hp upgrade w/o the constant speed prop.
This aviation stuff is fun.
- Andrew
Old September 18th 05, 01:53 PM
Andrew Gideon wrote:
: extra 20hp.
: Numerous older skyhawks have been converted to 180hp. I just helped my club
: buy one, and there were plenty on the market (although they were the
: minority, admittedly).
: Most still had fixed pitch props, but I did find one example that had been
: upgraded to a constant speed prop. Amusingly, while I'd never heard of
: that done before on a 172, the owner of that plane had never heard of a
: 180hp upgrade w/o the constant speed prop.
: This aviation stuff is fun.
I think that 180hp (or the rarely-seen 168hp low-compression version of the
O-360) is a great engine for a trainer++ class plane. As far as the constant-speed,
the only thing it really buys you is load/climb. If you don't get a gross weight
increase with a C/S 180hp upgrade, IMO it's not worth the added expense. As I've said
many time before, airframe determines speed (within reason)... not engine.
Just FYI, our -140 with a 180hp engine upgrade could have had the C/S as
well... it's and option with the engine STC paperwork.
-Cory
* Cory Papenfuss *
Archer Tach Red Arc Greg Esres Owning 15 February 9th 05 08:28 AM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
Dreamfleet/flight1 archer c310 FPS? Tlewis95 Simulators 4 February 2nd 04 12:12 AM
RNZAF Skyhawk Sale Update Errol Cavit Military Aviation 10 September 21st 03 09:46 AM
Piper Archer III or Cessna 172SP Dale Harwell Owning 10 July 15th 03 04:01 AM
