Ttransponder question #3
Old September 16th 05, 04:55 PM
Larry Dighera
On Fri, 16 Sep 2005 08:22:53 -0400, "TaxSrv" wrote
in ::
"Larry Dighera" wrote:
I don't think the transponders actually check for warmth.
A transponder contains what is termed a Crystal Oven. This is a
small
chamber in which there is a heating element and a quartz crystal
used
to determine the transponder's transmission frequency.
Which brands/models have that feature?? The frequency accuracy
required by the TSO can be and is achieved without a crystal oven.
The built-in turn-on delay is merely to allow the high-voltage
supply to come up to full volts, and the cavity tube filament to
heat up.
Fred F.
It was a long time ago that I was having difficulty with ATC receiving
the Mode-C of our King KT-78a. Now that you mention it, it was the
Mode-C blind encoder that had the heater in it, not the transponder.
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
