#31
"Ross Richardson" wrote:
So it is OFF and not just STANDBY? On King and Narco boxes, turning the thing to STDBY and back to Mode A or A/C accomplishes nothing to "recycle" the transponder, whatever that word is supposed to mean to the xpondr mfr! If the box has a microprocessor (King, Garmin), turning it off and on again may accomplish something, but doubtfully so. I liked the earlier post about twiddling the 4 code knobs. On older generation boxes with wafer switches which can crud up, that just may work. Same as to jiggling the box in the tray, if just Mode C is not working. Fred F. |
#32
Be that as it may, I believe most transponders just
wait a static timeout amount (30-45 sec), whenever transitioned from OFF to ON, even if you've already had it on. --- Jay Is simply what they do. The microprocessor in the Kings invariably sets the delay; Narco merely first charges up a capacitor which takes about 30 sec. So, whether she needs "warm-up" or not, it can't xmit until the light goes out. Fred F. |
#33
Turn it on and then say "roger .. how's that?"
"Ross Richardson" wrote in message ... What do you do when requested to "recycle" your transponder? -- ------------- Regards, Ross C-172F 180HP KSWI |
#34
![]() "OtisWinslow" wrote in message .. . Turn it on and then say "roger .. how's that?" There's no point in asking an aircraft to reset a transponder that hasn't been turned on. An aircraft that is instructed to recycle the transponder is usually one that has previously supplied a good beacon target. When an aircraft departs and no beacon target is seen where one should be seen the instruction is usually "verify you're squawking NNNN". |
#35
link.net... There's no point in asking an aircraft to reset a transponder that hasn't been turned on. An aircraft that is instructed to recycle the transponder is usually one that has previously supplied a good beacon target. When an aircraft departs and no beacon target is seen where one should be seen the instruction is usually "verify you're squawking NNNN". A few years ago I got a call from tower after departure to check my transponder. I don't remember his exact wording to me was to recycle or just to turn it on, but I replied that I was slash x-ray and never heard from him again... -Greg B. Still /X |
#36
TaxSrv wrote:
I liked the earlier post about twiddling the 4 code knobs.Â*Â*On older generation boxes with wafer switches which can crud up, that just may work. My xponder was once transmitting an incorrect code; one digit was off. In that case, I futzed with that one knob. - Andrew |
#37
A few times while flying home to KBIL on a cold night I've been told
that approach isn't getting my xpdr. Is this likely somehow related to the cold temp? Also, what is atc's attitude toward me hitting IDENT, and asking if that shows anything? (I know I'm leaving myself open here.) |
#38
![]() skym wrote: A few times while flying home to KBIL on a cold night I've been told that approach isn't getting my xpdr. Is this likely somehow related to the cold temp? No, just your crappy transponder. Also, what is atc's attitude toward me hitting IDENT, and asking if that shows anything? (I know I'm leaving myself open here.) Hitting ident won't change anything if the transponder isn't currently working. |
#39
Gee, it's only about 20 yrs old!!
#40
![]() Excellent advice. There are enough ways of hanging yourself without handing them one on a silver platter. Quite. Plus ATC really doesn't want to bust you as long as no separation was lost. They just want you back on altitude with the minimum of fuss. The last thing they want you to do is own up to the deviation on the tapes... |
I want to ask you the most important question of your life. | Douglas Olson | Owning | 1 | May 22nd 05 05:15 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
