Thanks Roger...good post. I do have to nitpick one little thing:
"Roger Long" wrote in message ... [...] Because of the symmetries required by conservation of energy, the pressure differential will be equal to the weight of the aircraft. Two problems: 1) Pressure is measured as a force over area. Pounds per square inch, for example. Lift is measured as a force. The two cannot be "equal"...they aren't the same kind of measurement. 2) Perhaps you meant to say that the pressure differential will be equal to the weight of the aircraft divided by the area of the wing. However, that's only true during unaccelerated flight. The airplane regularly is flown so as to create more or less lift than the weight of the airplane; it's an essential component of maneuvering. None of this, however, takes away from your nice way of presenting in a simplified way, why it is that the air speeds up over the top of a wing. Pete |
simplified way, why it is that the air speeds up over the top of a wing. I'm probably driving everyone who understands this crazy by now, but I'm still not getting it. Every time I think I am, I challenge myself to explain it to myself, and I fall down at the same point. And the point is ~still~ why the air speeds up over the wing at a positive angle of attack, and gets faster as the angle of attack gets greater. I grasp the concept that higher speed leads to lower pressure. That is settled. What is eluding me is the reason why the pressure is lower above the wing. I answer it by saying "the air is faster", but that brings me back to the question: "why does a wing oriented at an angle of attack make the air go faster?". Obviously I can't answer it with "because it lowers the pressure", because that would just cause me to ask "why does it lower the pressure?" which we would be answered by "because the air is going faster", which gets me back to the start. This is the short-circuit in my understanding at the moment. Roger's description here seems to make sense to me:- http://www.avweb.com/news/airman/183261-1.html "Since the wing is at an angle, its movement also tries to sweep out a space behind the top. The inertia of the air that goes over the top of the wing tries to keep it moving in a straight line, while the pressure of the atmosphere tries to push it down towards the wing's surface. The inertia prevents the atmospheric pressure from packing the space as firmly as it would if the wing were standing still. The result is a low-pressure region above the wing. Air rushes from high- to low-pressure regions, from the high-pressure area ahead of and below the wing into the low-pressure space being swept out above and behind it." ...... as does this:- http://www.allstar.fiu.edu/aero/airflylvl3.htm "So how does a thin wing divert so much air? When the air is bent around the top of the wing, it pulls on the air above it accelerating that air down, otherwise there would be voids in the air left above the wing. Air is pulled from above to prevent voids. This pulling causes the pressure to become lower above the wing. It is the acceleration of the air above the wing in the downward direction that gives lift." Are these enough to rely on to give a broad overview of what is going on above the wing? I actually think I do understand a fair bit of the stuff "downstream" of this point. I'm pretty sure that once the above concept clicks into place. Thanks in advance. I hope I'm not making anyone head butt their keyboards in frustration. |
The problem is that you are beating your self up with
which-came-first-the-chicken-or-the-egg type thinking. The answer to that conundrum lies in being able to step back and look at the larger picture of evolution. You can't figure this out going "ta duh tee dee da dum" either. All the aspects of flow adjust simultaneously to satisfy the requirement for energy conservation. Whenever the idea of "cause" intrudes into your thinking squash it. Instead look for the symmetries that create the balance that conserves energy and follow the energy flow. You can't have a change in flow with out changes in pressure. You can't have pressure differentials without flow (in an open system). All of these things being discussed are just aspects of what happens when a flow is set up in such a way that energy conservation requires an upwards force (lift) equal to the downward pull of gravity. None of them are "causing" any of the others. They are all caused by need for energy to be conserved. It is very simple and elegant once you can free your mind up from plodding point to point and can just see the whole picture. Why does the air speed up on top of an airfoil? Because none of the other requirements for lift to be produced could be happening together unless it was. -- Roger Long |
![]() xerj wrote: None of this, however, takes away from your nice way of presenting in a simplified way, why it is that the air speeds up over the top of a wing. What is eluding me is the reason why the pressure is lower above the wing. I answer it by saying "the air is faster", but that brings me back to the question: "why does a wing oriented at an angle of attack make the air go faster?". There are three types of air pressure. Total pressure is the total force exerted by all the air molecules in all directions. It is measured by a barometer. Dynamic pressure is the force exerted by molecules that have been accelerated in a particular direction. Blow air against your hand and you will feel dynamic pressure. Dynamic pressure is measured by a pitot tube. Static pressure is measured by the Bernoulli principle. It is the pressure of the remaining molecules that have not been accelerated in a particular direction. Static pressure is measured by your static port. Total pressure at any altitude must remain constant and it must equal the total of dynamic pressure plus static pressure. If you increase dynamic pressure in one direction by moving air over a wing, blowing it through a tube, against your hand, whatever, then static pressure must be reduced in order to keep total pressure constant. A wing increases dynamic pressure from front to back over the top, so static pressure is reduced. At the same time, the positive angle of attack on the bottom of the wing reduces dynamic pressure from front to back, so static pressure on the bottom is increased. This increase in pressure differential is not enough to account for total lift, however. The reduced static pressure above the wing also causes air to move down toward the wing, much as the reduced static pressure of water flowing through the nozzle of a garden hose sprayer forces fluid up and out of the bottle and into the nozzle. This air is caught up in the flow of the boundary layer and is also forced off the trailing edge of the wing and down. This actually generates most of the lift -- as air is forced down toward the wing and then down off the trailing edge, there must be an opposite and equal reaction and the wing is forced upward. You can see the air is forced down by the wing by watching an airplane fly over a cloud or smoke, or low over water. The downward moving air creates a canyon in the cloud or ripples on the water almost directly under the airplane. Air is accelerated over the top of the wing because the top is curved. Air molecules are forced upward by the leading edge, but because air is slightly sticky (viscous), it sticks to the wing rather than just continuing up. It is like holding a water glass sideways under a faucet; the water instead of just dropping straight down off the side of a glass instead follows the glass all the way around to the bottom and then falls off. Really, an airplane is nothing more than a fan blade. Instead of whirling around, it moves straight through the air. Air is drawn from above the wing and forced down behind it, just like a fan blade forces air through it. People get a little confused by watching wind tunnel streams, because in a wind tunnel the air is moving and the wing is stationary, so instead of moving down off the trailing edge the air in a wind tunnel is blown straight behind the wing. Instructors like to demonstrate the Bernoulli principle by blowing over the top of a sheet of paper. The paper rises, demonstrating lift. What instructors don't usually do, though, is blow under the paper. The paper still rises, demonstrating lift. As the angle of attack increases the boundary layer begins to separate from the wing, causing turbulence instead of lift, but lift continues to increase because of the greater lift coming from the area towards the leading edge. At some point, though, the angle of attack becomes so great that there is not enough lift to overcome the turbulence from the separating boundary layer and the wing stalls. |
Thanks to all: Jim Weir's - October 2000 (Understanding LED lamp indicators) | dwbauer | Home Built | 5 | June 17th 05 06:00 PM |
Jim Weir's - October 2000 (Understanding LED lamp indicators - Part II) | dwbauer | Home Built | 4 | June 9th 05 11:09 PM |
About Acellerated Courses for Private | Dudley Henriques | Piloting | 137 | July 22nd 04 04:21 AM |
Help understanding how to work with prepreg | Chris | Home Built | 4 | April 1st 04 02:13 PM |
"Understanding Aircraft Composite Construction" | Ernest Christley | Home Built | 2 | July 23rd 03 03:18 AM |
