Evan,
I understand the point you are trying to make and your numbers are not unreasonable. However, just for the same of argument, what if the airframe parts, ready to be assembled could be punched out for under $10,000? This is not unreasonable considering that Van's can sell a kit for $15,000 and still make a profit. And what if the engine could be supplied for under $10,000 too? This too is not unreasonable, considering you could buy a brand new PZL four-banger for that much money for a number of years. So now your total figure has dropped by $15,000 to $46,000. True this does not leave a lot of profit margin, but you are getting very close to the $50,000 factory-built airplane. Regards, Gordon. "Evan Carew" wrote in message ... Gordon, Based on my back of the envelope analysis of the theoretical base price of a 2 place aircraft, I think wishing for a plane costing less than 50K is nothing more than a pipe dream. If you use the following numbers as a guide, you'll see what I mean. Airframe + instruments + basic engine + labor = theoretical base price 20000 + 4000 + 15000 + ( 500 * 45 ) = 61500 Notice that this price doesn't include any profit, overhead costs or insurance. Add those in, & you quickly get to a point where $80K looks reasonable & $100K understandable. As I've mentioned before, until the structural issues affecting cost (labor & machined materials) are addressed with better up-front engineering, these costs won't come down. Evan |
Gordon,
This is exactly how the problem space needs to be framed. The economic solution to this problem is to rely on donations of high value engineering skills to jump start the production of aircraft parts with an eye to minimizing input labor costs. I own a company here in South-east Michigan that makes filter parts for oddball filtration systems. Since these parts are all custom, we paid a local CAD firm to do the designs, then passed those off to a machine shop that does work for GM. Its amazing how cheaply you can make parts if you do the up-front engineering on them first. IT also helps that we have underutilized quality machine shop capacity here surronding the auto companies. Should someone in the EAA, familliar with engines, whish to design a new engine (like the Jibaru) from scratch. This would be a good place to do it. I say from scratch because the Lycoming/Contenental combo aren't what I would call engineered for efficient manufacturing. Perhaps something like a cross between the Rotax & the Jibaru would work. As for the airframe parts, unless someone comes up with a process to dramatically reduce the labor in making a fiberglass fuse, I don't think we will be seing cheap airframe parts any time soon. On the other hand, if you don't mind assembling yourself, the aluminum option could work with CNCd parts. No, until someone comes up with a way to pull a fully primed and painted fiberglass part from a mold (no trimming/sanding required), we aren't going to see cheap airframe parts, however, maybe that's not as critical as it would seem. Looking at my numbers, a well engineered airframe for 20K still might not break the bank if you could get its assembly/surfas prep/painting labor costs way down. You'd literally have to engineer the entire process. So lets see... Time Process descrip cost at $45/hr 20 Airframe assembly $900 5 powerplant install $225 10 airframe surface prep $450 10 airframe painting $450 5 instruments $225 5 interior $225 5 testing $225 ---------------------------------------- 60 $2700 Now that's getting the price of the airplane down! Combine that with an engine for ~10K or even a little less & you have something: Airframe + instruments + basic engine + labor = theoretical base price 20000 + 4000 + 9000 + ( 60 * 45 ) = 35700 |
Evan,
I think your analysis is realistic -- and forethought in process engineering is critical. In fact, I think a lot of the European manufacturers already have a lot of these efficiencies in place. Europe and other parts of the world -- including Canada -- have already had special rules for light sport-type aircraft for a number of years and many of these airplane makers have been making these light planes for years. That's why they were srping-loaded to crank out these planes for the US market. However, there are a couple of factors here that work against a low price, chief among them being the strong Euro relative to the US greenback. The Rotax engine is expensive too and combine it with the fairly expensive and labor-intensive composite manufacturing process you have prices that are not as good as they could be. Also the European JAR certification is not as simple as LSA certification -- it more like "real" certification, but not as rigorous. So these outfits did have some real certification costs that are built into the planes. However, having said all that I still believe that there is an element of opportunism in their pricing -- which is only shooting themselves in the foot, by overpricing this market before it has even had a chance to flower. Don't forget that there is also an additional layer here for the US importer, so there is another middleman taking his cut. This is why you are seeing the $80,000 sportplane (more like $100,000 with decent panel options). In reality these planes already could be $50,000 planes if they were made here in North America -- Canada is a great manufacturing base, as Diamond Aircraft, Symphony and others will confirm. And if you had a good $10,000 engine you could make a nice profit with those $50,000 sportplanes. I really belive that aluminum is the way to go, however. Again, look at the Van's kit. Suppose you wanted to set up a factory to produce sportplanes. Your business plan would include a CNC facility for machining the metal pieces and you could stamp out parts with very high efficiency. The cost of aluminum is quite modest. I doubt there can more than about $1500 worth of aircraft aluminum in a 1,300 pound gross weight sportplane. With the right process in place and the tooling to crank out parts pre-finished to a reasonably high degree, the assembly time can be brought down to quite an efficient level. I think people like Van's and Murphy Aircraft in Canada, both of whom have facotries with lots of CNC and other sophisticated tooling already in place, are going to be thinking seriously about putting together finished all-aluminum sportplanes. (Their kitplanes are already aluminum-based.) I think in Europe composites have taken hold because of the vibrant sailplane industry that has existed there for decades and where composites have replaced wood construction for quite some time. I think the better ones are pretty efficieent at it by now. And once they see a North American company selling $50,000 sportplanes like hotcakes, you will see them suddenly jumping in with competitive pricing as well. And if none of that happens, the kit industry will keep on thriving. A kit from Van's or Murphy is a good value proposition. (For the really parsimonious, plans building is even more of a value propostion, as long as you don't count the TV-couch time that you are sacrificing to your airplane project). I think someone mentioned that there are about 20,000 amateur-built airplanes on the registry rolls now, but an even more impressive statistic I have heard is that there are actually more homebuilts certified each year than factory-built GA airplanes. If people vote with their wallets, which happens to be a good truism, this is a good indicator of what people think about the "value" of factory-built airplanes -- which is to say not much. Regards, Gordon. "Evan Carew" wrote in message ... Gordon, This is exactly how the problem space needs to be framed. The economic solution to this problem is to rely on donations of high value engineering skills to jump start the production of aircraft parts with an eye to minimizing input labor costs. I own a company here in South-east Michigan that makes filter parts for oddball filtration systems. Since these parts are all custom, we paid a local CAD firm to do the designs, then passed those off to a machine shop that does work for GM. Its amazing how cheaply you can make parts if you do the up-front engineering on them first. IT also helps that we have underutilized quality machine shop capacity here surronding the auto companies. Should someone in the EAA, familliar with engines, whish to design a new engine (like the Jibaru) from scratch. This would be a good place to do it. I say from scratch because the Lycoming/Contenental combo aren't what I would call engineered for efficient manufacturing. Perhaps something like a cross between the Rotax & the Jibaru would work. As for the airframe parts, unless someone comes up with a process to dramatically reduce the labor in making a fiberglass fuse, I don't think we will be seing cheap airframe parts any time soon. On the other hand, if you don't mind assembling yourself, the aluminum option could work with CNCd parts. No, until someone comes up with a way to pull a fully primed and painted fiberglass part from a mold (no trimming/sanding required), we aren't going to see cheap airframe parts, however, maybe that's not as critical as it would seem. Looking at my numbers, a well engineered airframe for 20K still might not break the bank if you could get its assembly/surfas prep/painting labor costs way down. You'd literally have to engineer the entire process. So lets see... Time Process descrip cost at $45/hr 20 Airframe assembly $900 5 powerplant install $225 10 airframe surface prep $450 10 airframe painting $450 5 instruments $225 5 interior $225 5 testing $225 ---------------------------------------- 60 $2700 Now that's getting the price of the airplane down! Combine that with an engine for ~10K or even a little less & you have something: Airframe + instruments + basic engine + labor = theoretical base price 20000 + 4000 + 9000 + ( 60 * 45 ) = 35700 |
Gordon,
Unfortunately, I have to disagree with you on your analysis of aluminum use in commercially built LSA aircraft structures. While it is true that the aluminum materials costs for an aircraft are lower, the labor costs (which I have already shown to be the largest cost in building any plane) are much higher, thus making it a poor choice if you are trying to build such airplanes for a profit. On the other hand, if you are trying to sell kit LSA airframes, then the builder assumes the labor costs, thus making a comparable kit seem less expensive. |
Evan,
I don't want to drag this out, I think some good points ahve been made -- however, I don't see why fiberglass airframe construction is going to be less labor-intensive. There is almost zero opportunity for automation in fiberglass construction, unless you go to specialized processes and tooling that are probably out of reach for a small firm. Even Cirrus and Adam do a lot of their layups by hand -- granted using pre-pregs. Now look at a simple little plane like the Zenith 601. They used to build one of these in a week at Oshkosh, using volunteers from the crowd. It uses pull-type rivets rather than bucked, so the structure can be assembled quite quickly. I think the total time to get to the flying plane was about 300 man hours. And I don't think the Zenith kit parts are as automated as they could be -- for instance I don't the they are fully precut and pre-punched etc. like the Van's kits. My point is that if you purpose-designed a small aluminum airplane for quick construction and automated the sheet-metal stamping part of the process, you could make that airplane very cost-effectively. Perhaps a fiberglass approach could work just as well, but I think more ingenuity would be required. Regards, Gordon. "Evan Carew" wrote in message .. . Gordon, Unfortunately, I have to disagree with you on your analysis of aluminum use in commercially built LSA aircraft structures. While it is true that the aluminum materials costs for an aircraft are lower, the labor costs (which I have already shown to be the largest cost in building any plane) are much higher, thus making it a poor choice if you are trying to build such airplanes for a profit. On the other hand, if you are trying to sell kit LSA airframes, then the builder assumes the labor costs, thus making a comparable kit seem less expensive. |
On Sun, 18 Sep 2005 23:37:30 -0400, "Gordon Arnaut"
wrote: Evan, I don't want to drag this out, I think some good points ahve been made -- however, I don't see why fiberglass airframe construction is going to be less labor-intensive. Once you have the moulds constructed, fiberglass lends itself well to making large compound structures as one piece. There is almost zero opportunity for automation in fiberglass construction, That depends on your thinking. Fiberglass composite also lends itself well to putting pieces together. unless you go to specialized processes and tooling that are probably out of reach for a small firm. Even Cirrus and Adam do a lot of their layups by hand -- granted using pre-pregs. Now look at a simple little plane like the Zenith 601. They used to build one of these in a week at Oshkosh, using volunteers from the crowd. It uses pull-type rivets rather than bucked, so the structure can be assembled quite quickly. I think the total time to get to the flying plane was about 300 man hours. And I don't think the Zenith kit parts are as automated as they could be -- for instance I don't the they are fully precut and pre-punched etc. like the Van's kits. My point is that if you purpose-designed a small aluminum airplane for quick construction and automated the sheet-metal stamping part of the process, you could make that airplane very cost-effectively. Perhaps a fiberglass approach could work just as well, but I think more ingenuity would be required. It would and it would. However, in the case of the sport plane specifications, the plane could be constructed of shells that could be fastened together. They could be composite shells, with the joggle and two aluminum strips where they would be pop riveted together with cherry max rivets. After all they do not under go any where near the stress of a Cirrus, Lancair, or Glasair III. Staying within those specs makes both the metal and composite structures much more simple. OTOH you still have all the insurance costs. If and I emphasize the IF the market were there to justify true mass production then airframes, engines and basic avionics could be produced at considerably less. If you could sell even 20,000 small displacement engines like the Jabaru they'd become *relatively* less expensive compared to now. Let's face it, even at Cessna's best year, that was a specialized market and peanuts compared to the automobile. However, first you have to have the market. You aren't going to do a lot of high profile advertising for a nitch market that may develop. Once the potential market is there the advertising can increase, and production will follow. It's much like the chicken or the egg. The market has to develop slowly. The faster it develops the more sensitive it is to upsets. However, I seriously doubt that we will ever see more than about three times the number of planes currently flying. Beyond that we'd need a complete now traffic system even if most of it is local. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Regards, Gordon. "Evan Carew" wrote in message . .. Gordon, Unfortunately, I have to disagree with you on your analysis of aluminum use in commercially built LSA aircraft structures. While it is true that the aluminum materials costs for an aircraft are lower, the labor costs (which I have already shown to be the largest cost in building any plane) are much higher, thus making it a poor choice if you are trying to build such airplanes for a profit. On the other hand, if you are trying to sell kit LSA airframes, then the builder assumes the labor costs, thus making a comparable kit seem less expensive. |
On Mon, 19 Sep 2005 03:47:38 -0400, Roger
wrote: On Sun, 18 Sep 2005 23:37:30 -0400, "Gordon Arnaut" wrote: Evan, I don't want to drag this out, I think some good points ahve been made -- however, I don't see why fiberglass airframe construction is going to be less labor-intensive. Once you have the moulds constructed, fiberglass lends itself well to making large compound structures as one piece. There is almost zero opportunity for automation in fiberglass construction, That depends on your thinking. Fiberglass composite also lends itself well to putting pieces together. I dunno, Roger. I've been both to the Glastar factory and the Vans factory. At Vans, a guy feeds a big piece of aluminum into a big CNC machine and whango-whango-whango out comes a big pile of RV parts. But then I go see the Glastar's fiberglass fuselage made, and its spray the release agent onto the mold, then the gelcoat, then cut pieces of fiberglass and lay them into the mold, then squeegee on some resin, then apply the foam, then apply another layer of fiberglass and more resin, etc. etc., lather, rinse, repeat, then let the assembly tie up your every expensive mold while the resin cures. Looked to me that manufacturing aircraft parts in fiberglass is a *lot* more effort...though I allow that less-skilled workers can probably be used. Ron Wanttaja P.S. Wanna hear something *really* scary? My spell checker passed "whango-whango-whango" but hiccuped on "gelcoat." |
Gordon,
All I'm saying is that there's more opportunity to do low labor per square foot of fuse with fiberglass than with aluminum, ans since we are talking about commercially built structures, that's all that matters when you are trying to get a basic airplane out the door for less than 80, or even 60K. As for using pull type rivets... do you really think any commercial entity is going to roll out insured airplanes with the equivalent of pop rivets? |
Evan Carew wrote:
As for using pull type rivets... do you really think any commercial entity is going to roll out insured airplanes with the equivalent of pop rivets? The windshields on the Bell Jetranger helicopter are held on by pulled rivets. I didn't know that until I saw one being replaced. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Could it happen he The High Cost of Operating in Europe | Larry Dighera | Piloting | 5 | July 14th 03 02:34 AM |
