I have a DG808, Cambridge L-Nav and GPS. I have always
turned the instruments on before starting the engine. At 00:42 18 September 2005, Hl Falbaum wrote: I just got a DG800B, with Dittel Radio and S-Nav/GPSNav setup. The Battery is 2 parallel 6v in series w/ 2 more parallel 6 v giving 12v 24 AH. As far as I can determine this is the standard DG800 setup. The former owner assures me that the avionics are not bothered by voltage spikes when starting or shutting down the engine. The GPS needs time at basline and uninterrupted recording after that for badge/record flight. I don't want to sit on the runway, idling the engine before takeoff. Our airport is not conducive to taxi out and go. Has anyone in r.a.s.-land had a problem with starting the engine with avionics on? Thanks -- Hartley Falbaum |
Is a motorglider a "powered aircraft" | Greg K. | Soaring | 27 | May 18th 05 05:34 AM |
time for avionics upgrade... | kontiki | Owning | 12 | December 11th 04 06:15 PM |
avionics shop - NJ, Eastern PA, IFR GPS | Ken | Owning | 11 | January 22nd 04 06:36 PM |
Used Avionics | O. Sami Saydjari | Instrument Flight Rules | 40 | December 2nd 03 02:53 PM |
Flying a motorglider without the engine? | Eric Greenwell | Soaring | 1 | September 23rd 03 05:38 AM |
