![]() xerj wrote: None of this, however, takes away from your nice way of presenting in a simplified way, why it is that the air speeds up over the top of a wing. What is eluding me is the reason why the pressure is lower above the wing. I answer it by saying "the air is faster", but that brings me back to the question: "why does a wing oriented at an angle of attack make the air go faster?". There are three types of air pressure. Total pressure is the total force exerted by all the air molecules in all directions. It is measured by a barometer. Dynamic pressure is the force exerted by molecules that have been accelerated in a particular direction. Blow air against your hand and you will feel dynamic pressure. Dynamic pressure is measured by a pitot tube. Static pressure is measured by the Bernoulli principle. It is the pressure of the remaining molecules that have not been accelerated in a particular direction. Static pressure is measured by your static port. Total pressure at any altitude must remain constant and it must equal the total of dynamic pressure plus static pressure. If you increase dynamic pressure in one direction by moving air over a wing, blowing it through a tube, against your hand, whatever, then static pressure must be reduced in order to keep total pressure constant. A wing increases dynamic pressure from front to back over the top, so static pressure is reduced. At the same time, the positive angle of attack on the bottom of the wing reduces dynamic pressure from front to back, so static pressure on the bottom is increased. This increase in pressure differential is not enough to account for total lift, however. The reduced static pressure above the wing also causes air to move down toward the wing, much as the reduced static pressure of water flowing through the nozzle of a garden hose sprayer forces fluid up and out of the bottle and into the nozzle. This air is caught up in the flow of the boundary layer and is also forced off the trailing edge of the wing and down. This actually generates most of the lift -- as air is forced down toward the wing and then down off the trailing edge, there must be an opposite and equal reaction and the wing is forced upward. You can see the air is forced down by the wing by watching an airplane fly over a cloud or smoke, or low over water. The downward moving air creates a canyon in the cloud or ripples on the water almost directly under the airplane. Air is accelerated over the top of the wing because the top is curved. Air molecules are forced upward by the leading edge, but because air is slightly sticky (viscous), it sticks to the wing rather than just continuing up. It is like holding a water glass sideways under a faucet; the water instead of just dropping straight down off the side of a glass instead follows the glass all the way around to the bottom and then falls off. Really, an airplane is nothing more than a fan blade. Instead of whirling around, it moves straight through the air. Air is drawn from above the wing and forced down behind it, just like a fan blade forces air through it. People get a little confused by watching wind tunnel streams, because in a wind tunnel the air is moving and the wing is stationary, so instead of moving down off the trailing edge the air in a wind tunnel is blown straight behind the wing. Instructors like to demonstrate the Bernoulli principle by blowing over the top of a sheet of paper. The paper rises, demonstrating lift. What instructors don't usually do, though, is blow under the paper. The paper still rises, demonstrating lift. As the angle of attack increases the boundary layer begins to separate from the wing, causing turbulence instead of lift, but lift continues to increase because of the greater lift coming from the area towards the leading edge. At some point, though, the angle of attack becomes so great that there is not enough lift to overcome the turbulence from the separating boundary layer and the wing stalls. |
Thanks to all: Jim Weir's - October 2000 (Understanding LED lamp indicators) | dwbauer | Home Built | 5 | June 17th 05 06:00 PM |
Jim Weir's - October 2000 (Understanding LED lamp indicators - Part II) | dwbauer | Home Built | 4 | June 9th 05 11:09 PM |
About Acellerated Courses for Private | Dudley Henriques | Piloting | 137 | July 22nd 04 04:21 AM |
Help understanding how to work with prepreg | Chris | Home Built | 4 | April 1st 04 02:13 PM |
"Understanding Aircraft Composite Construction" | Ernest Christley | Home Built | 2 | July 23rd 03 03:18 AM |
