In article . com,
" wrote: Here's one I just read: http://www.canada.com/montreal/montr...ry.html?id=cfe... Some fellow is claiming he has a small device that will boost combustion efficiency and save drivers lots of money, while reducing emissions. Obviously, plenty of claims have been made before, so I'm asking -- does this sound on the level? It sounds reasonable that injecting H2 into your fuel stream can improve the combustion. I assume that combusting the H2 in your cylinders along with the regular fuel will boost temperature to give a cleaner burn. Would the higher temperature harm your engine life at all? Since this device supposedly only holds a limited supply of distilled H2O, KOH, etc which get periodically replaced, can I assume that it's catalytically cracking some hydrogen from the hydrocarbon fuel stream itself, so that hydrogen can improve the combustion of the remaining fuel at the cylinder? Is this somehow akin to a sort of turbocharger, but which uses hydrogen instead of pressurized oxygen? Can it work for other things like aircraft engines, in order to boost their operating ceiling? Hmm, I dunno, I feel a little puzzled or suspicious of how he's achieving a net energy gain here. Can anyone debunk any obvious fallacies here? I read the web page ad, and every single paragragh had at least one outright falsehood. Some paragraphs had several. Most also had classical marketing misdirection and dissimulation. The bottom line? YOU CAN'T GET SOMETHING FOR NOTHING. Everything this guys says violates conservation of energy and both the First and Second Laws of Thermodynamics. It's a simple bilko scheme. -- Harry Andreas Engineering raconteur |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
fetters or fetter's booster? | Cy Galley | Home Built | 11 | March 12th 04 10:46 PM |
high-speed camera view of a piston intake, combustion, exhaust | R.Hubbell | General Aviation | 0 | February 20th 04 03:36 AM |
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes | Larry Dighera | Piloting | 5 | November 21st 03 02:13 AM |
