Electronic versus Pneumatic compensation (follow-up)
Old September 19th 05, 08:23 PM
John Galloway
I would expect a non-TE-compensated sensitive vario
like a Sage to be useless for soaring even with the
right flask and no leaks.
There is no theoretical reason not to attach 3 varios
to the one TE line with the exception of the consideration
of not wanting to mix a flow sensor vario (the Sage)
with pressure sensor varios (the other two) unless
the TE line is divided as far aft as is humanly possible
- as Paul says. In practice under the rear of the
seat pan is about as far aft as it is easy to reach
in a Schempp.
A big mistake to avoid is to have a restrictor in the
TE line aft of the Y division in the line. In that
case airflows flow from the Sage will be even more
encouraged to go back and forth between that and the
other 2 varios because the flow resistance is less
than the resistance back down the rear fuselage tube
to the TE probe. If you decide to use any sort of
flow restrictor then make sure it is forward of the
Y junction - but better still forget it. There is
no flow from the two other varios so the branch of
the TE line to them can be divided close to the instruments.
A good TE probe is a very clever device that produces
the inverse of pitot minus static pressure and not
the inverse of total pitot pressure (as is commonly
mistakenly believed) and it also has good performance
with yaw and pitch changes. It is amazing to me that
instrument manufacturers and pilots opt to use 2 pressure
sensors one of which (the static source) is highly
yaw sensitive and then electronically combine these
poorer sources to get electronic TE compensation when
a good quality correctly sited TE probe provides the
correct pressure correction at source. So it is better
and faster - always - to use pneumatic TE unless there
is something wrong with the probe or the installation
or the pneumatic tubing.
So - check for leaks, right connections and correct
flask, do without nasty restrictors, make sure you
have a good quality TE probe, keep the varios on pneumatic
TE and divide the TE line between the Sage and the
other 2 varios as far aft as possible - IMHO.
John Galloway
At 17:00 19 September 2005, Paul Remde wrote:
Hi Ted,
The strange behavior of the Sage vario suggests that
you may not be using
the correct size capacity flask. There are several
size capacity flasks
available. Please check the documentation for the
vario. I give dimensions
for a few Winter capacity flasks on my Winter page
he
http://www.soarmn.com/cumulus/winter.htm#W-9014
I think the idea of using a filter in line with the
vario is a bad one.
It may work OK to connect all 3 to the TE source as
long as the connection
to the Sage is a long way (3m? - behind your seat)
from the connection to
the LX7000 and 302. But I think that if you want the
Sage to be a TE vario
you may want to use an independent TE source for it.
I have never tried to connect 3 TE sources to a single
TE so I can't say for
certain whether that will work or not.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
For you instrument installation experts out there,
I'd like to pick
your brain if you have a circular tuit.
My new glider (a Ventus 2C) came with a Sage (model
CV) vario, Winter
ASI and altimeter, and nothing else that connects
to pressure sources.
Last week a Cambridge 302 and a new LX7000 were installed.
When the new hardware was installed, all the tubing
was replaced except
for the one from the capacity bottle (behind the pilot
seat) to the
Sage, which is also connected to static pressure.
No restrictor was
installed in the latter. So the Sage setup wasn't
modified in any way.
The C-302 and LX7000 were both installed on the TE
source and
configured internally for TE (not electronic) compensation,
so at the
time of my first flight Saturday, those were the only
two instruments
connected to the TE probe.
The Sage was virtually useless during my two flights
on Saturday (my
first in the glider). It swung wildly and rapidly
in all directions.
The 302 and the LX seemed to work fine.
A fellow pilot suggested that I add a restrictor in
the form of a
cigarette filter to the Sage's pressure source. The
result yesterday
was a very, very calm needle, maybe too calm (some
of the filter will
be removed). But I still found its reading to be quite
different from
the 302's. Some to be expected, of course, since the
Sage was on
static source while the 302 was on the TE. On light
pull-ups, the stick
thermals were 10 to 15 knots!
Anyway, all that's the background. I want to switch
the Sage from
static to TE pressure source so it acts more like
the B-40 of my
previous glider (which was on the TE). But I have
been warned not to
put more than one or two instruments on the TE pressure
source, because
they have a certain amount of built-in 'leak' or 'loss'
as part
of the PFM they do.
This is what I would like feedback on - if it's really
inadvisable
to put 3 or more instruments on the TE. If it's a
Bad Thing, my plan
will be to move the C-302 from TE to electronic compensation,
and leave
the LX7000 with the Sage on the TE. Any thoughts on
this too? ... or
should I put the LX7000 on electronic compensation
too and leave the
Sage alone on TE?
Advance thanks
-ted/2NO
Old September 20th 05, 12:31 AM
Eric Greenwell
yaw sensitive
I thought static sources were carefully chosen to be yaw insensitive.
The one on my ASH 26 E seems to be that way - I have to yaw a large
amount to affect the ASI, for example.
poorer sources
These days, the sensors are very good.
This was true years ago, but I don't think it is universally true
anymore. I know several pilots with Cambridge 302s, including myself,
that find the electronic TE works just as well as the TE probe.
Eric Greenwell
Washington State
USA
Old September 20th 05, 06:21 PM
Hi
I have electronic TE on my LX 5000. I do not notice any yaw
sensitivity, maybe it is because front and rear static source are used
togetter on my LS6 with this instrument. It is a very good system. This
installation was on the aircraft when I got it last year.Not at all
different from the Lnav I had for 10 years on my previous glider, which
was very good. The damping was set at 7 in the instument by the
previous owner.
I did not touch anything it is perfect as is. I do not have any other
vario. I have been flying like this for 16
years now. No problem.
Gilles
Electronic versus Pneumatic compensation in LX7000 [email protected] Soaring 8 September 15th 05 02:49 AM
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA Otis Willie Naval Aviation 0 April 30th 04 09:45 PM
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA Otis Willie Military Aviation 0 April 30th 04 09:45 PM
