Selling my Garmin GPSMap 296
Old September 19th 05, 11:36 PM
Kobra
No...need a new engine. Toasted mine three weeks ago.
Kobra
"Mike Granby" wrote in message
I am parting with my Garmin 296 if anyone is interested.
You, and a million others. Buying a 396, by any chance?
Old September 20th 05, 01:48 AM
John Doe
How did you do that?
"Kobra" wrote in message
Kobra
Old September 20th 05, 02:27 AM
Mike Granby
Urgh. Sorry to hear that. What happened?
Old September 20th 05, 03:38 PM
Kobra
I have a Cardinal RG with a IO-360A1B6 with 1000 hours on it. On one short
30 min. flight to Cape May, NJ (WWD) I noticed a small amount of oil running
down the nose gear door. I did a cursory look and found the oil level
unchanged and saw nothing through the oil access door. I wiped it off.
On the flight back all oil indicators were fine. When I landed the drip of
oil was back. No big oil loss, but when you fly the same airplane you know
what's suppose to be there and what's not. I called my mechanic and
co-owner and explained the problem. At first the mechanic was not
concerned.
My partner flew a few days later on a short flight and when he landed the
A&P came over to say hello. He then noticed the oil on the gear door. He
grounded the plane and the next day called me to the airport. He showed me
a pretty good leak coming through something called a "though-bolt" on the
number two cylinder. A though-bolt is a long bolt that goes completely
through the engine from one cylinder to the other and helps keep the case
enlighten and tight.
That wasn't the big problem though, he said I could fly with a minor leak at
the through-bolt to TBO. Next he did a dye penetrate test and found a crack
in the case in front of the number 4 jug at one of the studs for that
cylinder. That did it. The engine had to come off, the case split and a
new case was ordered.
The story goes on though. As he was taking the engine off he found one
other interesting item. One of the through-bolt nuts on the bottom of
cylinder number 3 was sheared off completely flush the cylinder base.
That's when the hair on the back of my neck stood up. I have to think that
all this was related as the nut was still laying in the bottom of the
engine. This was recent!
Next I had a recollection of starting the engine before my flight to WWD and
I remember that I heard a "snap!" just as the engine caught. It was loud
enough to make me say, "...what the %$#@ was that?!" and just soft enough
for me to dismiss it and ponder, "...did you really hear what you think you
heard?"
The rest is speculation, but maybe that was the nut snapping off and
something bad happened in the engine causing the leak at the through bolt on
number two cylinder. Maybe the engine was ready to self-destruct in the air
on the next flight. Who knows? But I hope to learn more when the engine is
broken down and inspected. I will keep you all posted if you are
interested.
Kobra
Old September 20th 05, 03:49 PM
heard?"
So true... Always the hard question is how do you distinguish between
when the engine goes auto-rough every time you fly over water versus
the truly exceptional snap.
A year ago I turned the key in my Jeep, and it seemed to start pretty
sluggishly, but started nonetheless. Engine ran brilliantly so I
dismissed it. It wasn't cold or anything, I just chalked it up to
gremlins. Five minutes later I double-parked to grab a coffee, came
back out, turned the key, and -clunk-. That sluggish start was the
starter's last gasp. Had I known I could have driven it to a mechanic
and avoided the tow, but it was still under warranty so at least it
only cost me time and not cash.
-cwk.
Selling my Garmin GPSMap 296 Kobra Owning 12 September 20th 05 03:49 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
For Sale Garmin GPSMAP 196 Snead1 Soaring 0 May 14th 04 03:10 AM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
