Eric Greenwell wrote:
Jancsika wrote: Or any other cheap mouse type GPS. The final igc file will be fine ![]() This badge&cheap GPS issue come up year by year. Few enthusiastic pilot joined and created COTS proposal to IGC but nothing has changed so far ![]() Like it, or not, if one wants to get a badge with an EW, one must use one of the Garmin GPS units listed in the approval document... Marc It's just funny to see the weakness of the system... It's my understanding the IGC file will NOT be fine if a mouse type GPS is used, because it will be missing the NMEA sentence with the datum that is in use. With a Garmin GPS, the sentence is not sent only when the datum is changed, but with every data point. I also suspect the Garmin GPS sends a sentence identifying itself, which is recorded in the file, but I don't know that for sure. Perhaps Marc or other knowledgeable person can comment? At startup some GPS sends (even a cheap mouse type could do it) this data but to get a valid IGC file boot messages doesn't have to be in the NMEA stream. I sent you one example (Vali-ewa.exe validated this). Regards, /Janos |
First badges 2005 Marfa, TX | Burt Compton | Soaring | 0 | January 2nd 05 02:28 PM |
Cheap GPS Loggers for FAI Badges - Status? | Papa3 | Soaring | 154 | June 17th 04 10:33 PM |
Cheap GPS Loggers for FAI Badges - FAI Footdragging | stephanevdv | Soaring | 1 | June 9th 04 01:44 PM |
GPS Hand Held for Badges | Papa3 | Soaring | 17 | June 1st 04 09:12 PM |
