On 9/20/2005 12:45, xyzzy wrote:
wrote: As far as instrument training at night, there are good things and bad things. The only real bad thing is it may be more difficult to read charts and such over dim and/or colored cockpit lighting. If you're still still learning the intricacies of reading IFR charts and plates, that can add a bit of congestion to your already overloaded head. Yes, I started IFR training in the winter of last year and did a lot of basic manuevers and chartless approaches (talked through it by the instructor) at night. By the time I was doing aproaches and flying with charts, it was light at my usual training time. Now that it's gettting dark earlier, I'm surprised at how hard it is to put together two things I did well independently (maneuver at night under foggles + use charts). I too saw this the first time I did a cross county IFR training flight at night. I had to look at the chart and determine on which bearing I was from various VORs along the route. There is a larger work load when having to point a flashlight at the chart, then at the panel to scan the instruments, then back to the chart, etc. It would have been easier if my light had been brighter, but there's a cost associated with that (in reduced night adaptation). On the plus side, lots of the subtle visual cues that you get while wearing foggles aren't there. The small peripheral vision leaks out the side of the foggles, the sun changing angles on the instrument panels, etc.... those are pretty much gone at night. You'll have a more realistic environment to train for true "lack of outside references." I disagree with this. When at night under the foggles, when you fly over towns or cities, the glow from the ground is really noticeable in your peripherial vision. Because of this I feel like at night I'm actually getting more visual cues than I should when under the foggles. I agree with this as well. While training, I used to try to ignore all the visual cues (and was able to get disoriented from time to time) - flying at night didn't make this any easier... but I was flying over the valley between Oakland and Sacramento - not the darkest part of the planet to be sure. IMO the best VFR conditions for hood training are hazy southeastern afternoons. Of course, as others have said - nothing beats actual IMC for giving you respect for IMC ;-) If any pilot (or prospective pilot) hasn't experienced it yet, they should grab an instructor and go do it; regardless of their Instrument Rating aspirations. It will really open your eyes - Especially if you think "How hard can it be?" ;-) -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
: It would have been easier if my light had been brighter, but there's
: a cost associated with that (in reduced night adaptation). Just for the record, I have made (IMO) the perfect chart light for night flying. I took a regular minimag flashlight (2-AA type) and replaced the bulb with a single green LED. The smaller one (3/4 T or something... don't remember the size packages of LEDs offhand) is almost the same size as the original light bulb. I had to rig in a resistor (47 Ohm IIRC) in between the two AA's to limit the current. Anyway, bottom line is that it's just enough light to read the features of the chart easily, but not too much to destroy your night vision. Useless as a regular flashlight, but it's perfect for charts and it'll last almost forever on a single set of batteries. : I agree with this as well. While training, I used to try to ignore all : the visual cues (and was able to get disoriented from time to time) - : flying at night didn't make this any easier... but I was flying over : the valley between Oakland and Sacramento - not the darkest part of : the planet to be sure. I'm a bit skewed. Here in the mountains southwest Virginia, there aren't all that many lights. Certainly little "glow from below". You'd have to see the lights out of your peripheral vision to get references from them. I found daylight shadows moving (and my fixed-pitch prop loading/unloading the engine) the most irritating "cheats" to simulated IMC. : : IMO the best VFR conditions for hood training are hazy southeastern : afternoons. : : Of course, as others have said - nothing beats actual IMC for giving : you respect for IMC ;-) If any pilot (or prospective pilot) hasn't : experienced it yet, they should grab an instructor and go do it; regardless : of their Instrument Rating aspirations. It will really open your eyes - : Especially if you think "How hard can it be?" ;-) Absolutely agree. My instructor had me do actual for some of my instrument work for my private. It was a nice, February high overcast chilly day... spent about 20 minutes 500' up in a solid overcast (but above MEA for the area). It felt like 20 hours and I never knew I could sweat so quickly. Here I am... probably about 30 hours total, flying in solid soup using 98% of my brainpower to keep the shiny side up. Instructor leans over and points at the windshield saying, "See that? That's airframe ice." Anyway... enough to instantly instill respect for IMC and icing. Good experience to have under controlled circumstances so you don't blunder into it yourself. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Stan Gosnell wrote:
: I have a minimag that uses AAA batteries, and put a green LED in it. The : T3 is the right size. I got it from Mouser. I haven't seen the need for : a resistor - it just plugs into the holes for the regular bulb. I wear : it on a lanyard around my neck so I can always find it. But I seldom use : this. I normally use a cheap headlight, which has 2 bright white bulbs : and a single green LED. It came with red, but I changed it out for : green. The white is very useful for preflights and startup, and the : green works well for flying. It always points where I'm looking, and : doesn't blind my FO when I need to read charts and do the company : paperwork. I also carry a regular AA minimag, with a 2 Amp LED bulb and : a diffusion lens, for when I really need light, especially for preflight : walkarounds. White LEDs are great for preflights, because the synthetic : turbine oil in the sightglasses can be hard to see using a weak yellow : incandescent lens. The white LED light makes it show up very well. I've run LEDs directly from AA's and found that without a bit of current limiting they tend to damage themselves. Perhaps the AAA has a bit more internal resistance or the LEDs you chose are a little more resilient or slightly different material and operating voltage. In any event, I agree that a headlamp would be nice... haven't rigged one up yet. Trouble with all the commercial LED lights I've seen is that they're set up to be like regular flashlights. You know... flood the area with as much light as possible. That'll wreck any night vision in a heartbeat. The single LED works great (as you've also found out). -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
: one. Red light makes reading charts and LCD-based too hard to read for
: me. Also, it makes no sense to me to use red light when the instrument : lights are white anyway. The human eye is most sensitive to green light, : so you need less of it to make things visible. My aircraft has red cabin illumination, but with the dimmer it can be turned *way* down. Between that and the tiny green LED light, you can even make out some semblance of color. I think I read somewhere that the red/green debate is that red light damages night vision the least. That's a fact. Turns out, what's more important to preserving night vision is the *amount* of light. Since the eye is most sensitive to green, it can be at a lower level than red and still be useful. My completely anecdotal experiences have bourne this out. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Student night solo? | Peter MacPherson | Piloting | 50 | November 10th 04 01:51 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
