You did better than a very experienced local club member who had the
same problem many years ago in a DG300. He had one air brake open on tow, released early instead of gaining altitude and time, misjudged the approach and rolled it up in a ball. In the worst case you should be committed to an approach and landing with both airbrakes full open. Don't we practice that? Andy |
![]() Andy wrote: You did better than a very experienced local club member who had the same problem many years ago in a DG300. He had one air brake open on tow, released early instead of gaining altitude and time, misjudged the approach and rolled it up in a ball. In the worst case you should be committed to an approach and landing with both airbrakes full open. Don't we practice that? Andy |
Same thing happened to my partner in the ASW17/23m we had due to a
universal coupling failing at one of the rod ends in the left wing. Ground checked okay, but failed on final. Some damage to the wing underside and a hunt for parts, but we were flying the mighty 17 again before long. Rich |
rich schrieb:
Same thing happened to my partner in the ASW17/23m we had due to a universal coupling failing at one of the rod ends in the left wing. Ground checked okay, but failed on final. Some damage to the wing underside and a hunt for parts, but we were flying the mighty 17 again before long. Rich We had the same happen in a ASK-21 on final. Looked spectacular, but fortunately the rear-pilot was experienced enough to keep calm. Touchdown was a bit sideways but rather normal - no damage. Reason: after rigging the plane it was checked by someone who did not know the (then new) Hotelier connections on the '21. ouch... and the person he asked to check his work later forgot.... Cu around and happy landings! Markus |
On 21 Sep 2005 21:16:29 -0700, "Andy" wrote:
You did better than a very experienced local club member who had the same problem many years ago in a DG300. He had one air brake open on tow, released early instead of gaining altitude and time, misjudged the approach and rolled it up in a ball. Hmmm... the DG-300 has fully automatic control hookups for the flaps. How could that happen? Bye Andreas |
In article , Andreas Maurer
writes On 21 Sep 2005 21:16:29 -0700, "Andy" wrote: You did better than a very experienced local club member who had the same problem many years ago in a DG300. He had one air brake open on tow, released early instead of gaining altitude and time, misjudged the approach and rolled it up in a ball. Hmmm... the DG-300 has fully automatic control hookups for the flaps. How could that happen? Bye Andreas I didn't think the DG 300 had flaps. -- Mike Lindsay |
My! In the DG-300 it is impossible to misrig the flaps.
So far I've never seen a flapped -300... On the other hand, it's impossible to misrig an automatic hookup bird. If the wings are in place, the controls are ok. You can forget to screw the tail in place, as in the ASW-24, but it is not possible to leave the ailerons/spoilers unconected. "Andreas Maurer" escribió en el mensaje ... On 21 Sep 2005 21:16:29 -0700, "Andy" wrote: You did better than a very experienced local club member who had the same problem many years ago in a DG300. He had one air brake open on tow, released early instead of gaining altitude and time, misjudged the approach and rolled it up in a ball. Hmmm... the DG-300 has fully automatic control hookups for the flaps. How could that happen? Bye Andreas |
J.A.M. wrote:
My! In the DG-300 it is impossible to misrig the flaps. So far I've never seen a flapped -300... On the other hand, it's impossible to misrig an automatic hookup bird. There are a few older gliders where this is possible. If the wings are in place, the controls are ok. You can forget to screw the tail in place, as in the ASW-24, Schleicher has a simple retrofit (for many of their gliders - not just the 24) that keeps the tail bolt with the elevator and reduces the chance of this happening. It's worth doing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
We do practice that here.
But many places do not practice for this. Full spoilers deployed ( to achieve symmetry) through approach, from the point of unlocking through flare/round out and touchdown. The typical error we find made by pilots in this configuration is the tendency to "hurry" on approach, with extra airspeed, and not understand how it will affect their glide slope. It should be much less of a handling worry to make the glider symmetrical, and control the approach in a regular configuration, than to begin to think of all the "different" things you could do to accommodate the asymmetry. Just because there are several stories reported here of pilots who either "didn't notice" their configuration issues, or handled them with aplomb, remember that this is frequently Not The Case for just as many others. We also practice/teach approaches with spoilers completely closed, but that is a different thread. Cindy B Caracole Soaring |
![]() "CindyASK" wrote in message ups.com... We do practice that here. But many places do not practice for this. Full spoilers deployed ( to achieve symmetry) through approach, from the point of unlocking through flare/round out and touchdown. The typical error we find made by pilots in this configuration is the tendency to "hurry" on approach, with extra airspeed, and not understand how it will affect their glide slope. It should be much less of a handling worry to make the glider symmetrical, and control the approach in a regular configuration, than to begin to think of all the "different" things you could do to accommodate the asymmetry. Just because there are several stories reported here of pilots who either "didn't notice" their configuration issues, or handled them with aplomb, remember that this is frequently Not The Case for just as many others. We also practice/teach approaches with spoilers completely closed, but that is a different thread. Cindy B Caracole Soaring Good thoughts. Good also to keep in mind that many gliders will have the wheel brake fully applied with full spoiler deployment making the touchdown 'interesting'. Once, long ago, I tested the effect of asymmetrical spoiler deployment to find out if it would make a suitable roll control. I found that I could twist around in the seat of a 1-26 just enough to pull one of the spoiler cables behind the spar box. I was surprised to find that the roll/yaw effect was small - at least at normal approach airspeeds. As long as the airspeed is not too high, asymmetrical spoiler can be controlled with rudder and aileron. Of course, at higher speeds, the yaw from an open spoiler will overpower the rudder because drag is proportional to the square of the airspeed. Somehow, rudder authority doesn't increase at the same rate. Bill Daniels |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
