![]() "Steven P. McNicoll" wrote in message nk.net... "John Clonts" wrote in message ups.com... or should they just know it already? I was departing Sugarland (KSGR) yesterday, after having gotten my clearance from ground control. How much time elapsed between getting your clearance and taxiing for departure? About 2-3 minutes. Tower assigned me runway heading (this was about 45 minutes later as there was MUCH traffic waiting in line for takeoffs) and handed me off to departure. Do they normally send VFR aircraft to departure? Have no idea about that, it's not a familiar airport to me. I had trouble getting a word in edgewise, but when I eventually did, departure said "change squawk to 0044". Later a different controller (but same freq I believe) asked my if I was VFR???? I told him "Negative, N7NZ is cleared Industry departure then as filed, currently on 270 vector". He said, "roger, cleared direct IDU", and the rest of the flight was uneventful (and unambiguously IFR). This was all in VMC. How did you come to be on a 270 vector? Sugarland has only a north-south runway and the tower assigned runway heading. Who then assigned a west heading and for what purpose? Hmm, yes, I may have that sequence out of order. I was given the new squawk, and sometime after that I was asked if I was VFR, but I can't remember if I was given the vector before or after the VFR question. Later I thought that maybe the tower didn't realize I was IFR when he cleared me for takeoff, and that fouled something up with departure. If some time elapsed between issuance of IFR clearance and taxiing for departure ground control may have forgotten that you were an IFR departure and prepared a new VFR strip for local control. Did you request taxi right after getting your clearance? If not, did you tell ground you were IFR when you called for taxi? It was only 2-3 minutes, and I did not tell him I was IFR at taxi time. But it was 45 minutes later when I was finally #1 for departure. Or, is there another reason I would have immediately been given a new squawk code like that? I seem to remember that 0xxx squawks are "local" or something like that. Yet I believe I then kept that same 0044 the entire remaining duration of the flight (through Houston Center and then Austin Approach to my destination 44TE). Are you sure the code was 0044? The National Beacon Code Allocation Plan assigns codes 0100-0477 to terminal operations, it doesn't assign the block 0000-0077 to any purpose (which I find rather odd). Since your flight was entirely within Houston Center you should have been assigned a code from one of ZHU's internal departure blocks; 45xx, 46xx, or 47xx. Yes, I am sure about the 0044, I just checked where I had written it on my clipboard. The original code I was given by ground control was 4553. Thanks! John |
![]() "John Clonts" wrote in message ... About 2-3 minutes. Then the episode appears to be a brain fart on the part of the ground controller. |
![]() "Steven P. McNicoll" wrote in message ink.net... "John Clonts" wrote in message ... About 2-3 minutes. Then the episode appears to be a brain fart on the part of the ground controller. If so, what was it he did (or didn't do) incorrectly? Thanks, John |
![]() "John Clonts" wrote in message ... If so, what was it he did (or didn't do) incorrectly? It appears he forgot that he had just issued you an IFR clearance and treated you as a VFR departure. |
Los Angeles radio tower crash kills 2 | Paul Hirose | Piloting | 178 | August 6th 05 03:46 PM |
Tower Enroute Control? | Sam Jones | Instrument Flight Rules | 5 | June 2nd 04 02:31 AM |
New Oshkosh Tower | Jay Honeck | Piloting | 20 | November 25th 03 05:35 PM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Home Built | 4 | July 26th 03 11:34 AM |
Oshkosh Get together Roster - Sign in, please! | Jay Honeck | Piloting | 0 | July 24th 03 04:15 AM |
