![]() "Lynne" wrote in message oups.com... Santa Monica (KSMO) requires you to call ground prior to engine start. So just how do they require that? |
It is broadcasted on the ATIS. If you do not call for engine start, and
simply call ground to taxi, you WILL be told to hold your position. The airport is very tight, so they don't want aircraft that do not have their IFR release blocking access to the runway. In other words, when you call for start clearance, your IFR release is coordinated. Lynne |
![]() "Lynne" wrote in message oups.com... It is broadcasted on the ATIS. What is broadcast on the ATIS? If you do not call for engine start, and simply call ground to taxi, you WILL be told to hold your position. The airport is very tight, so they don't want aircraft that do not have their IFR release blocking access to the runway. In other words, when you call for start clearance, your IFR release is coordinated. So they don't taxi IFR aircraft until they've been released. That's not a requirement to call ground prior to engine start. |
I think what you are forgetting is that the AIM is not regulatory. From
the looks of it, it is as if you're expecting to get a violation if you start your engine prior to calling ground. That just won't happen. This thread has gotten out of hand. The bottom line is that if you start your engine, then get your clearance, then call ground, it may end up wasting your time with the engine running if there are delays. But, no matter what, you will never get in "trouble" for starting your engine prior to getting the clearance, or talking to ground. Lynne |
On 25 Sep 2005 11:02:02 -0700, "Lynne" wrote:
I think what you are forgetting is that the AIM is not regulatory. From the looks of it, it is as if you're expecting to get a violation if you start your engine prior to calling ground. That just won't happen. This thread has gotten out of hand. The bottom line is that if you start your engine, then get your clearance, then call ground, it may end up wasting your time with the engine running if there are delays. But, no matter what, you will never get in "trouble" for starting your engine prior to getting the clearance, or talking to ground. Lynne It's not clear to whom you are responding, but if you are claiming that I am "expecting to get a violation" then your inference is completely wrong. My question, to which no one has yet responded, was why this mostly ignored AIM paragraph is present. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Lynne" wrote in message oups.com... I think what you are forgetting is that the AIM is not regulatory. From the looks of it, it is as if you're expecting to get a violation if you start your engine prior to calling ground. That just won't happen. This thread has gotten out of hand. The bottom line is that if you start your engine, then get your clearance, then call ground, it may end up wasting your time with the engine running if there are delays. But, no matter what, you will never get in "trouble" for starting your engine prior to getting the clearance, or talking to ground. Or, in other words, there's no requirement to call ground prior to engine start. |
So.. if the ATIS says "contact ground/clearance" prior to engine start,
does that constitute instruction from "air traffic control" which must be complied with except in an emergency? and is not obtaining (and complying with any instructions on) the ATIS failure to obtain all relevant information regarding the proposed flight? Can you reconcile these concepts (loosely paraphrased from the part 91 rules regarding ops) with what you are saying that there is "no requirement to call ground prior to engine start" when in some circumstances there appears to be? Dave Steven P. McNicoll wrote: "Lynne" wrote in message oups.com... I think what you are forgetting is that the AIM is not regulatory. From the looks of it, it is as if you're expecting to get a violation if you start your engine prior to calling ground. That just won't happen. This thread has gotten out of hand. The bottom line is that if you start your engine, then get your clearance, then call ground, it may end up wasting your time with the engine running if there are delays. But, no matter what, you will never get in "trouble" for starting your engine prior to getting the clearance, or talking to ground. Or, in other words, there's no requirement to call ground prior to engine start. |
![]() "Dave S" wrote in message k.net... So.. if the ATIS says "contact ground/clearance" prior to engine start, does that constitute instruction from "air traffic control" which must be complied with except in an emergency? No. FAR 91.123(b) states, "Except in an emergency, no person may operate an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised." Ramps are not areas in which air traffic control is exercised. Note that a taxi clearance is only required to operate on a runway or taxiway. If I can taxi on a ramp without contacting ground control I can certainly start an engine without calling them. and is not obtaining (and complying with any instructions on) the ATIS failure to obtain all relevant information regarding the proposed flight? Not obtaining it might be, not complying with it is not. Can you reconcile these concepts (loosely paraphrased from the part 91 rules regarding ops) with what you are saying that there is "no requirement to call ground prior to engine start" when in some circumstances there appears to be? If there is a requirement to call ground prior to engine start it will be found in the FARs. You will find no such requirement there. The local flying field here has a statement on the ATIS telling departures to five specific airports to advise ground control five minutes prior to engine start. It's for flow control purposes, the five airports are those for which a flow release is required. The only penalty for not calling ground prior to engine start is the potential fuel wasted on the ground waiting for the release time. |
"Lynne" wrote in message oups.com... Santa Monica (KSMO) requires you to call ground prior to engine start. So just how do they require that? - CURFEW: NO ENGINE STARTS OR DEPS EXPECT PPR LIFEGUARD FLTS 2300-0700 MON-FRI AND 2300-0800 WKENDS. |
![]() "Dave Butler" wrote in message news:1127763096.162487@sj-nntpcache-5... - CURFEW: NO ENGINE STARTS OR DEPS EXPECT PPR LIFEGUARD FLTS 2300-0700 MON-FRI AND 2300-0800 WKENDS. The tower is closed during those hours. |
No SID in clearance, fly it anyway? | Roy Smith | Instrument Flight Rules | 195 | November 28th 05 10:06 PM |
Touch and Goes versus Full Stop Taxi Backs | Kevin Dunlevy | Piloting | 81 | September 18th 05 09:26 PM |
Clearance: Direct to airport with /U | Judah | Instrument Flight Rules | 8 | February 27th 04 06:02 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
