Cleaning Spark Plugs is a Simple Job...
Old September 25th 05, 04:35 AM
Orval Fairbairn
In article NwoZe.161520$084.66032@attbi_s22,
"Jay Honeck" wrote:
When you finished, did you "properly" store the torque wrench?
(Just a test to see if you read the instructions that came with the
tool.)
Um, well, I very carefully put it back in the cheap plastic case it came in,
and wrapped the directions around the handle.
Was there more to it?
Yup. You are supposed to reset the torque setting to zero when you put
the wrench away. Otherwise, the torque wrench can acquire a set and lose
calibration -- usually it will click early, or a a lower than designated
torque.
Need Champion C26 Spark Plugs (era circa WW-II). J. Graham Owning 1 July 30th 05 05:57 PM
Spark Plugs: Champion vs. Unison Jonathan Goodish Owning 7 May 6th 05 11:19 PM
Unison spark plugs Ed Sullivan Home Built 3 April 21st 05 02:10 PM
Color of spark plugs john smith Owning 5 March 2nd 04 03:08 AM
Spark plugs for ASH26E Ludovic Launer Soaring 4 February 3rd 04 07:56 PM
