a écrit:
It got me to poking around on some european website. I found the specs for the ford 1.4 litre diesel sold over there. Not sure how the figures size up to gas engines currently in use. Any Opinions? These engines are "Light weight" only for automotive use. The 1l4 is a Peugeot design, you may choose a 1l6 (DV6 TED4) with the same weigt and power up to 110HP@4000rpm. http://minilien.com/?krjU8zHgIx I am not sure, but I read "around" 100kg for the engine. You still kneed a PSRU. I think you may have a 110HP engine for 120-130kg minimum. It is still heavier than mogas engine. Just for fun: with this type of engine, you may got 50mpg on car like Toyota Corolla. By -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Stuart & Kathryn Fields wrote:
Just a point. On one 700 mile trip in my VW Jetta TDI, holding the speed to between 55 and 60mph, I got 55mpg. Normal use is 45mpg or better. just googlise that: diesel "2CDDI-II" and you will see that http://www.daihatsu.com/motorshow/frankfurt05/pdf/e.pdf The most désirable diesel for light aircraft may be hide in the 2CDDI-II name. Just wait more news about weight. By. -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Here is the VW tdi as an industrial engine.
Given the application I would expect there is a big honkin flywheel on this thing that would be removed for aviation purposes. Then after replacing the the alternator etc etc. It would still be heavy, but potentially doable. http://www.maesco.com/products/vwp/v...dieselpto.html Anyway, it's something interesting to look at. -Matt |
![]() wrote in message Here is the VW tdi as an industrial engine. Given the application I would expect there is a big honkin flywheel on this thing that would be removed for aviation purposes. Then after replacing the the alternator etc etc. It would still be heavy, but potentially doable. I would wonder about the potentially doable part. It is nearly 300 lbs, and only 78 HP. Even if you could get 100 lbs off of it, (doubtful) that would still be 200 lbs, for less than 80 HP. That is bad in anybody's book. -- Jim in NC |
If I had said "spectacular" I would understand your beef.
Here are the respective weights of a few engines for comparison. Engine HP Weight(lbs) Comments ------------------------------------------------------------------------------------ Continental A-65 65 173 Limbach L 1800 66 154 Limbach L 1700 66 161 Rotax 618 74 136 Includes 20 lbs radiator, etc. Great Plains VW 2180CC 75 165 Franklin 225 75 230 _______________________________________________ "doable". It wouldn't be efficient. But it would fly. If one fiddled with the wastegate or injection computer they could probably get more power. The guys with the powerstrokes are doing some crazy things these days and some of that tech would probably carry over to the TDI. What do you fly by the way Jim? Can i get an "s" ? -Matt |
Maybe some of these will help. Seem to be working well in the cars.
http://dieseltuning.ca/ http://www.upsolute.com/eng/index.html Some talk about the rocket chip: http://www.upsolute.com/eng/index.html Some controls can be programed with this: http://www.ross-tech.com/ David Ervin wrote in message oups.com... Here is the VW tdi as an industrial engine. Given the application I would expect there is a big honkin flywheel on this thing that would be removed for aviation purposes. Then after replacing the the alternator etc etc. It would still be heavy, but potentially doable. http://www.maesco.com/products/vwp/v...dieselpto.html Anyway, it's something interesting to look at. -Matt |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | November 23rd 03 11:43 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | October 29th 03 02:33 AM |
New WWII books from Germany | ArtKramr | Military Aviation | 0 | October 13th 03 12:54 AM |
