![]() "Roger" wrote in message ... On 24 Sep 2005 08:10:59 -0700, wrote: If this thread is true to the subject of H2 boosting, not H2O The subject has drifted, it happens. Or using some method of cracking water to get Hydrogen it's unlikely it can do any thing near what is claimed. To get H2 from water takes a lot of energy. OTOH adding water to hot charcoal will produce a burnable gas and is a regularly used process. Well it was back in the days when we made town gas from coke. The gas produced was of course mainly carbon monoxide which would modern safety officials a fit. Surprisingly H2 does not have the flame temperature for which it is often given credit. Nor does it have a high BTU content per unit volume. What it does have is a small molecular structure which lets you put a lot of it through a small tip on a torch providing a clean, hot, flame with enough BTUs for melting glass and even quartz. Water vapor in the fuel stream serves two purposes. It lowers the combustion chamber temperature and it effectively increases the octane rating of the gas under high compression. Introduced into the inlet stream it can lower the temperature of the incoming fuel/air mixture which will allow more mixture into the chamber for a given pressure. Indeed Alcohol which has a low octane rating although it keeps getting credit for a high one, when added to gas up to 10% by volume will increase the octane rating of the fuel. 10% seems to be the maximum amount for increasing the octane rating. One side effect of water injection is nice clean cylinders and cylinder heads. Water also adds a lot of weight, without adding much else. There really are no magic additives, or fuels that will give tremendous savings on their own. Well there is one, tetraethyl lead boosts the octane rating allowing you to use much higher compression ratios. Of course there certain drawbacks which caused it to be banned. Most cost far more than normal gas. Even those who make the claims of tremendous added mileage by adding battery capacity to a hybrid car are not taking into account all the added costs including the cost of the electricity. Not exactly. Using battery technology allows the IC engine to run only at its max efficiency setting and allows the use of regenerative braking Its easily shown that hybrid cars do give better gas mileage Some where in the $3.00 to $3.50 range per gallon of gas is the point where alternative fuels begin to become economically viable alternatives to non renewable hydrocarbons. They have been well above that level in Europe for at least a decade. The result has been a large scale switch to more efficient diesel engines and the proeuction of relatively small amounts of bio-diesel. Beyond that there have been relatively few such advances. Current gas prices here in the UK are around $6.8 per gallon We see all kinds of claims using byproducts from one place or another, but as soon as enough people use those products they no longer are thrown away they will be right up there with the other alternative fuels. We are most likely going to soon see $3.50 per gallon for a short time here in the states. That will affect world wide prices which should only be for a few months depending on how fast refining capacity can be put back on line. Dont bet on it. World demand is rising faster than supply, specifically the Chinese are rapidly building a massive automotive industry and Chinese demand for oil is rising at around 1 bbpd / year In 2004 China became the worlds second largest importer of petroleum products surpassing Japan. That demand is now at approx 40% that of the USA having risen by 300% since 1990 The scary part is the news tonight was reporting a gas leak out in the gulf where the lines come together before the gas is brought to shore. Wait till you see your LP and natural gas bills this winter. Most commercial electricity is produced by burning natural gas. Only if you include dual fired units, the stats in 2004 were (million kilowatts) Coal 313.3 Oil 36.9 Gas 222.9 Dual Fuel 175.4 Hydro 79 Nuclear 99.6 Electricity production is of course much easier to switch to non fossil fuels than automotive fuel use but the USA hasnt built any commercial nuclear plants since the 1980's unlike France which now generates almost 90% of its electricity from nuclear sources. Keith |
On Sun, 25 Sep 2005 11:39:49 +0100, "Keith W"
wrote: "Roger" wrote in message .. . On 24 Sep 2005 08:10:59 -0700, wrote: If this thread is true to the subject of H2 boosting, not H2O The subject has drifted, it happens. It does? :-)) snip Well it was back in the days when we made town gas from coke. The gas produced was of course mainly carbon monoxide which would modern safety officials a fit. They also made something similar to natural gas snip There really are no magic additives, or fuels that will give tremendous savings on their own. Well there is one, tetraethyl lead boosts the octane rating allowing you to use much higher compression ratios. True it indirectly contributes by raising the octane rating which allows for much higher combustion ratios. Gone are the days of gas engines with 11:1 compression ratios. Of course there certain drawbacks which caused it to be banned. Not just the lead. The higher compression had a tendency to create a lot of nitrides. Most cost far more than normal gas. Even those who make the claims of tremendous added mileage by adding battery capacity to a hybrid car are not taking into account all the added costs including the cost of the electricity. Not exactly. Using battery technology allows the IC engine to run only at its max efficiency setting and allows the use of regenerative braking Its easily shown that hybrid cars do give better gas mileage That wasn't quite where I was headed. I agree the hybrid can get much better mileage than a conventional car although it's at its best in city driving. Where I was headed was those adding more batteries to the hybrid and then charging them from the electrical mains. Although at first it looks like they are creating tremendous savings, it really a very expensive proposition and we haven't reached the point where disposing or remanufacturing the NiMH batteries has become a problem. Although the technology could allow the gas engine to run at max efficiency that isn't necessarily the case so there is still room for improvement. Yes, the motor/generator (wheel motor) is where the car gets most of its efficiency and also why it does its best in city driving. I'm wondering if may have noticed the similarity between the auto industry now and the auto industry back in the 70s after the gas shortage. The US auto industry was hurting as they were still geared up to produce cars that were part of the horse power race and consumer purchasing habits had shifted to imported economy cars. It appears, at least to me, to be much the same at present. We conserved, gas became cheap, and within a few years we were back to larger cars. However some pretty big strides were made in gas mileage. I drive an SUV that gets better mileage than the 4 cylinder cars I drove back in the late 80s and early 90s. but gas mileage has actually dropped slightly on average over the last 5 years or so. Some where in the $3.00 to $3.50 range per gallon of gas is the point where alternative fuels begin to become economically viable alternatives to non renewable hydrocarbons. They have been well above that level in Europe for at least a decade. The result has been a large scale switch to more efficient diesel engines and the proeuction of relatively small amounts of bio-diesel. Beyond that there have been relatively few such advances. And you have much quieter, smoother running, and cleaner diesel engines than we do here. Most of ours sound like a bad case of spark knock or a loose rod. :-)) Current gas prices here in the UK are around $6.8 per gallon We see all kinds of claims using byproducts from one place or another, but as soon as enough people use those products they no longer are thrown away they will be right up there with the other alternative fuels. We are most likely going to soon see $3.50 per gallon for a short time here in the states. That will affect world wide prices which should only be for a few months depending on how fast refining capacity can be put back on line. Dont bet on it. World demand is rising faster than supply, specifically the Chinese are rapidly building a massive automotive industry and Chinese demand for oil is rising at around 1 bbpd / year In 2004 China became the worlds second largest importer of petroleum products surpassing Japan. That demand is now at approx 40% that of the USA having risen by 300% since 1990 True, but due to price controls they are exporting refined gas as they can sell it for more than they can at home. I'd answer more but there's a thunderstorm right outside ... :-)) Later. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com The scary part is the news tonight was reporting a gas leak out in the gulf where the lines come together before the gas is brought to shore. Wait till you see your LP and natural gas bills this winter. Most commercial electricity is produced by burning natural gas. Only if you include dual fired units, the stats in 2004 were (million kilowatts) Coal 313.3 Oil 36.9 Gas 222.9 Dual Fuel 175.4 Hydro 79 Nuclear 99.6 Electricity production is of course much easier to switch to non fossil fuels than automotive fuel use but the USA hasnt built any commercial nuclear plants since the 1980's unlike France which now generates almost 90% of its electricity from nuclear sources. Keith |
![]() "Roger" wrote The scary part is the news tonight was reporting a gas leak out in the gulf where the lines come together before the gas is brought to shore. Wait till you see your LP and natural gas bills this winter. Most commercial electricity is produced by burning natural gas. I heard this, but only as a quick blurb. What is said to have caused this leak? My guess (if someone had a gun to my head forcing me to speculate) would be a dragging "super anchor" from a floating oil platform. -- Jim in NC |
On Sun, 25 Sep 2005 05:27:54 -0400, "Morgans"
wrote: "Roger" wrote The scary part is the news tonight was reporting a gas leak out in the gulf where the lines come together before the gas is brought to shore. Wait till you see your LP and natural gas bills this winter. Most commercial electricity is produced by burning natural gas. I heard this, but only as a quick blurb. What is said to have caused this leak? My guess (if someone had a gun to my head forcing me to speculate) would be a dragging "super anchor" from a floating oil platform. Sorry for the interruption/incomplete answer earlier. The thunderstorm is long past. Actually a whole bunch have passed with a whole bunch more coming through. I lost power 3 or 4 times momentarily, but the computers kept right on chugging along complete with UPS alarms sounding. Last I heard they didn't say any thing about the cause, or even any speculation. News was they were going to go out today and have a look. I don't know just how deep the gulf is at the Henry Hub location. I'd not expect the hurricane to disturbe the waters that deep, but then again there may be surface structures in the vicinity or something may have dragged across, or one of the pipes may have been "pulled". A lot of stuff seems to have done a bit of moving around out there. I stand corrected on the % of coal Vs Gas generated electricity. That's what I get for using the news:-)) I saw another blurb that listed projected increases as 12% for electricity, I think it was in the 30% range for fuel oil, and in the high 70% range for natural gas. The analysts seemed to be breathing a sigh of relief even with those figures. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote in message ... On Sun, 25 Sep 2005 05:27:54 -0400, "Morgans" wrote: "Roger" wrote The scary part is the news tonight was reporting a gas leak out in the gulf where the lines come together before the gas is brought to shore. Wait till you see your LP and natural gas bills this winter. Most commercial electricity is produced by burning natural gas. I heard this, but only as a quick blurb. What is said to have caused this leak? My guess (if someone had a gun to my head forcing me to speculate) would be a dragging "super anchor" from a floating oil platform. Sorry for the interruption/incomplete answer earlier. The thunderstorm is long past. Actually a whole bunch have passed with a whole bunch more coming through. I lost power 3 or 4 times momentarily, but the computers kept right on chugging along complete with UPS alarms sounding. Last I heard they didn't say any thing about the cause, or even any speculation. News was they were going to go out today and have a look. I don't know just how deep the gulf is at the Henry Hub location. I'd not expect the hurricane to disturbe the waters that deep, but then again there may be surface structures in the vicinity or something may have dragged across, or one of the pipes may have been "pulled". A lot of stuff seems to have done a bit of moving around out there. Given the two opposing movements produced by a hurricane and the shallow water in which the "Henry Hub" is likely to be located, far less than 100 fathoms, I'd guess early on that the amount of movement caused by the initial outflow of water toward the storm, followed by the surge, are likely to have exceeded the limits of one of more of the flexible couplings attaching the collectors (or the shore line) to the hub. One problem is that the waters are filled with stirred up sediment and sand and will take a while to clear for suitable diving conditions - They are never very clear. - and the second, pre-dive if possible, isolating the line(s) the coupling(s) of which is/are leaking and shutting off the flow of gas. I'm sure the structure has a valving system installed which prevents cross and back flows. The natural gas price issue is less clear than the superficial reaction makes it out to be.... I own a small interest in a gas producing property, itself a few wells which share production from a single underground "pool" of natural gas under pressure. This production is generally sold under contract, in our case to Phillips which owns the nearby pipeline which collects the gas. When the price jumps as it has and will this winter, our earnings will be dependent on the terms (and the time) that have been negotiated for the gas. Would that there were no contract, today, for I'd get fat and happy quicker. The result, gas burned to make electricity or piped to home or industry, which has been purchased at several different prices. Overall, I expect natural gas's "overall" price increase to be in the 30-35% range this Winter. ......But have I got a deal for you (or for me, really). Over on the edge of East Texas, I own what is now a 1/25 interest in the "Mineral Rights" to 532 acres+/- in the 1911 survey (actually now 540 acress by the survey when the "land" - surface rights - was recently sold). 15,000 feet (and $3-5,000,000 worth of drilling) beneath the surface is natural gas, by all evidence and indication in production quantities (which means that a dry hole is possible, but that the risk is acceptable). If a production company knocks on the door ready to drill (and willing to pay an acceptable percentage), the potential value of the gas, all "new" and ready to be sold at today's spot market prices, 2 or 3 times that of old gas, is substantial. The poor *******s buying "country places" and "ranchettes" up top have no say in the matter and would only receive token payments and compensation for a drilling rig in their backyards or a "Christmas Tree" next to the car port. As for me, I'sd be planning vacations, long vacations, permanent unemployment and relaxed retirement. I stand corrected on the % of coal Vs Gas generated electricity. That's what I get for using the news:-)) I saw another blurb that listed projected increases as 12% for electricity, I think it was in the 30% range for fuel oil, and in the high 70% range for natural gas. The analysts seemed to be breathing a sigh of relief even with those figures. TMO |
On Mon, 26 Sep 2005 14:52:08 GMT, "TOliver"
wrote: "Roger" wrote in message .. . On Sun, 25 Sep 2005 05:27:54 -0400, "Morgans" wrote: "Roger" wrote I am one of the very few, to the consternation of the drilling company doing the leasing, who refused to lease the mineral rights on our farm. It is one of very few parcels of land in central Michigan not under contract. Not far from here are some of the highest head pressures you can find. Unfortunately the gas is very deep and although there are a *few* new wells, most have been capped. They are not dry holes. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"Roger" wrote
I am one of the very few, to the consternation of the drilling company doing the leasing, who refused to lease the mineral rights on our farm. It is one of very few parcels of land in central Michigan not under contract. Not far from here are some of the highest head pressures you can find. Unfortunately the gas is very deep and although there are a *few* new wells, most have been capped. They are not dry holes. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger, How much pressure does the average well have on it in your local area? How deep do they drill up there? Most leases around here are for 3 years and are 7500 to 9500 feet deep. Some go to 11000 feet though. A few wells have up to 10000 psi of pressure on the casing but most local wells are a few thousand. We are currently undergoing the biggest drilling boom since the early 1980's. South of here 60 or 70 miles are some wells that are over 20,000 feet deep. ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "TOliver" wrote in message ... snip .....But have I got a deal for you (or for me, really). Over on the edge of East Texas, I own what is now a 1/25 interest in the "Mineral Rights" to 532 acres+/- in the 1911 survey (actually now 540 acress by the survey when the "land" - surface rights - was recently sold). 15,000 feet (and $3-5,000,000 worth of drilling) beneath the surface is natural gas, by all evidence and indication in production quantities (which means that a dry hole is possible, but that the risk is acceptable). If a production company knocks on the door ready to drill (and willing to pay an acceptable percentage), the potential value of the gas, all "new" and ready to be sold at today's spot market prices, 2 or 3 times that of old gas, is substantial. The poor *******s buying "country places" and "ranchettes" up top have no say in the matter and would only receive token payments and compensation for a drilling rig in their backyards or a "Christmas Tree" next to the car port. As for me, I'sd be planning vacations, long vacations, permanent unemployment and relaxed retirement. What is the going rate for surface damages per acre in your neck of the woods? Damages aren't "chicken feed" where I'm from. I know some people who have completely paid for their land from damages alone. Also, the surface owners do have a say, at least around here. They can negotiate water wells, fencing, brush clearing, location placement, road building, cattle guards, etc. That's not to say they always get what they ask for... but if other oil companies are competing for the same parcel then often they do. Do you mean you own one twenty-fifth share of the production or are you saying you own one twenty-fifth of 740 acres of the minerals. If it's the former is that all they will allow you as a sole mineral owner. We are getting 1/4 to 3/8ths of the wells production. What is the going lease rate per acre? I suspect yours is much higher than ours. ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
On Sat, 24 Sep 2005 23:45:43 -0700, Roger wrote
(in article ): Alcohol which has a low octane rating although it keeps getting credit for a high one, when added to gas up to 10% by volume will increase the octane rating of the fuel. 10% seems to be the maximum amount for increasing the octane rating. Can you explain the octane rating? In my little world octane is a chain of 8 carbons with 18 hydrogens hooked on. -- Charlie Springer |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
fetters or fetter's booster? | Cy Galley | Home Built | 11 | March 12th 04 10:46 PM |
high-speed camera view of a piston intake, combustion, exhaust | R.Hubbell | General Aviation | 0 | February 20th 04 03:36 AM |
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes | Larry Dighera | Piloting | 5 | November 21st 03 02:13 AM |
