Charlie Springer wrote:
On Sat, 24 Sep 2005 23:45:43 -0700, Roger wrote (in article ): Alcohol which has a low octane rating although it keeps getting credit for a high one, when added to gas up to 10% by volume will increase the octane rating of the fuel. 10% seems to be the maximum amount for increasing the octane rating. Can you explain the octane rating? In my little world octane is a chain of 8 carbons with 18 hydrogens hooked on. It's how resistant the fuel is to spontaneous ignition. (Detonation) Octane Rating really only applies to numbers below 100. The detonation resistance of a fuel blend is compared to that of a blend of iso-octane. An octane number of 100 is equivalent to the knock resistance of 100% octane. Strictly speaking, numbers above 100 aren't Octane Numbers, but Performance Numbers. It has nothing to do with energy content. The energy content of petroleum based hydrocarbon fuels is actually fairly constant, at somewhere around 18,000-19,000 BTU/lb. (Density, of course, varies. Gasolines are consedered to weigh in at about 6.0 lbs/U.S. gallon, while Kerosines like Jet-A weigh in at around 6.7 lbs/U.S. gallon.) In fact, most high octane gasolines have a lower energy content than low octane fuels. The increased knock resistance allows the engine to use that energy more efficiently. Methanols are considered to be around 150 Octane (Well. Performance Number) - but the energy content is low, so you've got to burn a lot of it, and it doesn't atomize well, so carburetor jets and injectors need to be redesigned. -- Pete Stickney Java Man knew nothing about coffee. |
On Wed, 28 Sep 2005 18:02:49 -0700, Charlie Springer
wrote: On Sat, 24 Sep 2005 23:45:43 -0700, Roger wrote (in article ): Alcohol which has a low octane rating although it keeps getting credit for a high one, when added to gas up to 10% by volume will increase the octane rating of the fuel. 10% seems to be the maximum amount for increasing the octane rating. Can you explain the octane rating? In my little world octane is a chain of 8 carbons with 18 hydrogens hooked on. Hexane, Heptane, Octane, ...actually it doesn't have anything to do with the number of nanes...:-)) It's an anti-knock rating. The lower the number the more prone to spark knock (detonation) the fuel would be under compression. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com -- Charlie Springer |
![]() Charlie Springer wrote: On Sat, 24 Sep 2005 23:45:43 -0700, Roger wrote (in article ): Alcohol which has a low octane rating although it keeps getting credit for a high one, when added to gas up to 10% by volume will increase the octane rating of the fuel. 10% seems to be the maximum amount for increasing the octane rating. Can you explain the octane rating? In my little world octane is a chain of 8 carbons with 18 hydrogens hooked on. Memory fades but the standard test for octane rating goes something like this: A standard engine is set up and run on the fuel to be tested. Than a standard additive (hmm, pure octane perhaps?) is added to the fuel until the engine begins to kock. The more of that additive it takes to make the engine knock, the higher the octane rating. The rating posted on gas pumpps in the US is the average of a bench test and a test on an engine installed in a vehicle. Or something like that. Octane rating is an indicator of the fuel's resistance to predetonation (knocking). It is not an indicator of how good the fuel is in other repsects. -- FF |
![]() Harry Andreas wrote: In article .com, wrote: Charlie Springer wrote: ... Can you explain the octane rating? In my little world octane is a chain of 8 carbons with 18 hydrogens hooked on. Memory fades but the standard test for octane rating goes something like this: (Actually, memory was crap) Or something like that. Something like that... Or something rather different, thanks. -- FF |
![]() Octane rating is an indicator of the fuel's resistance to predetonation (knocking). It is not an indicator of how good the fuel is in other repsects. Minor nit: My understanding is that you can have either "detonation" or "pre-ignition" but I've never heard of predetonation. Detonation is not the same thing as pre-ignition. Detonation is the sudden combustion of the fuel air mixture, or rather the more quickly burning of the mixture, after it has been ignited by the spark plug. Some people call it an explosion but it really is not, it's just that the mixture burns up so much more quickly that the piston is still close to the TDC position, so the combustion occurs in a very tightly squeezed area and the ringing sound you hear is the shock waves of the very quick burning of the mixture. Engines can stand a small measure of detonation for a very long time before anything bad happens to them. In fact for a while, engines were tuned such that some detonation during high pressure, low rpm was normal and expected. Pre-ignition, on the other hand, is always bad and VERY destructive. Pre-ignition is when the mixture gets ignited from some heat source (like a glowing piece of carbon or a too hot spark plug tip) prior to the spark plug sparking. If this happens too soon, the peak pressure point can occur while the piston is still rising in the cylinder. This is disasterous in terms of loss of power and results in the production of intense heat which can and has caused the very quick total disintegration of the piston, or worse. Corky Scott |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
fetters or fetter's booster? | Cy Galley | Home Built | 11 | March 12th 04 10:46 PM |
high-speed camera view of a piston intake, combustion, exhaust | R.Hubbell | General Aviation | 0 | February 20th 04 03:36 AM |
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes | Larry Dighera | Piloting | 5 | November 21st 03 02:13 AM |
