This is what happens when you're a schmuck and fly into IMC without an
Instument Rating... Only happens if you're a "schmuck" though, and cannot happen if you have an instrument rating. I'm not sure if this was a tongue-in-cheek post, or not -- but there are quite a few "loss of control in IMC" accidents every year by pilots with an IR in their pocket. Not to say it's not a good thing to have, but an instrument rating ain't a "get out of jail free" card unless you're proficient and flying well-maintained iron. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I will second that Jay.
-- Bill Snow, CP, IA, ASEL "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci |
I'll chime in too. The flying in IMC requires even more practice than a
VFR-only ticket with less room for mistakes. Equipment limitations demand more respect as well. All of this means that an IR makes some people safer while others become more dangerous. Marco Leon "William Snow" wrote in message . .. I will second that Jay. -- Bill Snow, CP, IA, ASEL "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
To go back to the original post - I'm going to play spoiler here...
Other than pointing the hapless pilot towards VFR Wx (which he should have known before departing) after the pilot recovered the aircraft, what did ATC contribute? Did the controller reach out and fly the airplane? As I hear the recording, after all the pilots screaming into the mike, the controller's reply was soothing but that was all... By the time the pilot replied without screaming, he had already seen a tower go by, figured out where down was, corrected his attitude, and the airplane was upright and in visual conditions (or at least semi visual)... ATC then instructed him to climb back into hard IMC so they could document the crash coordinates on radar!!! While that pilot may believe that ATC saved his bacon I have a different take on it... They held his hand on the radio which is certainly to their credit (99.9% of controllers are good folks)... But putting a VFR pilot back into the clouds was not the way to go... Clouds rarely go all the way to the ground... The fact that he could climb the airplane back into hard IMC and maintain control while changing headings, etc.., means he is a better pilot than given credit for... If he had climbed back into the clag and then yanked the wings off, ATC would have been answering hard questions to his wife's lawyers... He was lucky to survive his error resulting in a spiral (complete rolls unlikely, just a confused inner ear)... ATC was lucky to survive their error in climbing a vfr pilot back into imc... denny |
![]() Denny wrote: While that pilot may believe that ATC saved his bacon I have a different take on it... They held his hand on the radio which is certainly to their credit (99.9% of controllers are good folks)... But putting a VFR pilot back into the clouds was not the way to go... Listen again. The FSS guy said "remain VFR if able" and the pilot said "climbing to 3000" and later that he was in complete IFR. Seems to me the pilot made the call to go back up. -cwk. |
I'd like to know what kind of editing was done on the piece. I find the
transition from dramatic panic to calm to be a little too quick. The fact that it's part of a campaign doesn't help make me any less skeptical either. -- Gene Seibel Tales of Flight - http://pad39a.com/gene/tales.html Because I fly, I envy no one. |
Good point. One second he's screaming like a panicked VFR pilot who
screwed up badly, the next second we have "Iceman." Just another data point to suggest that flying is not for amateurs. At a minimum, all should have IRF ticket. |
minimum, all should have IRF ticket. I don't want to be around guys who are working on their "IRF" ticket... :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Marco Leon (at) wrote: I'll chime in too. OK, I'll bite. I agree with Jay's basic statement that an IR is not a magic wand, but that's not saying much. The flying in IMC requires even more practice than a VFR-only ticket with less room for mistakes. Apples and oranges, to some degree. Flying a successful XC mission in the system is an order of magnitude more complex than simply surviving a VFR-into-IMC encounter. IFR students are typically capable of holding heading and altitude within a few hundred feet in the first 10 or so hours, while passing the checkride takes 50 or more. At least in my case, the first things I get rusty on are procedures, like hold entries. Basic attitude flying (you don't need to pass a checkride, just survive) will likely last a lot longer between re-training. Equipment limitations demand more respect as well. All of this means that an IR makes some people safer while others become more dangerous. Individually, yes. As a population, no. Why does every insurance company give discounts for IR? Why do they effectively require it for higher-performance planes? It sometimes seems to me that the only people suggesting the IR doesn't significantly increase safety are unrated pilots. Now, the -utility- of the rating is a whole 'nother question on which I have decidedly mixed feelings. -cwk. |
