Cleaning Spark Plugs is a Simple Job...
Old September 27th 05, 07:22 AM
RST Engineering
"mikem" wrote in message
(10MegOhm), while the other six ranged from 1.4K to about 7K.
I expected all of these to be the same resistance, but was surprised at
the variablity plug to plug. I am puzzled at the two that read open.
They were not misfiring before removal. What's going on?
No problem. The ones that read open had a sub-thousandth crack on the
resistor and would arc across the crack before going to the two orders of
magnitude larger crack called a spark gap.
btw- I also measured 12 brand-new RHM40Es; 4 of 12 were open end to
end???
QC strikes again. They only "bomb test" the suckers. If there is a minute
crack between the resistor and the plug, they figure that the plug gap will
predominate in the sparking mechanisms. With the obvious comment that a
spark in oxygen rich atmosphere will wear down a contact MUCH further than
in the combustion chamber. Thus a failed plug in a few hundred hours. I'd
suggest you reject the opens. Unless we all continue to do so, plug
manufacturers will be getting away with this slop.
Old September 27th 05, 03:29 PM
We learned a long time ago to bomb-test even brand-new
plugs. We've had new Champs fail right out of the box. It can't be just
a tiny crack in the resistor; there has to be something else going on
here. When I remove that screw inside the barrel and take out the
spring and resistor, I can't find anything wrong with it. And if I take
that stuff out of a working plug, it doesn't want to work again after
reassembly. I think there's something wrong with the spring-loaded
resistor concept.
The old Auburn plugs had a molded-in resistor that seldom
failed, and AC copied that idea but have had some trouble anyway.
Now here's a debate: The resistor was originally to reduce
radio interference in automotive plugs. Since aircraft plugs are
shielded, that's not necessary. The textbooks say that the resistor is
there to shorten the spark duration and reduce electrode erosion.
Wouldn't it be better to leave the resistor out and accept shorter but
consistent plug life?
Dan
Need Champion C26 Spark Plugs (era circa WW-II). J. Graham Owning 1 July 30th 05 05:57 PM
Spark Plugs: Champion vs. Unison Jonathan Goodish Owning 7 May 6th 05 11:19 PM
Unison spark plugs Ed Sullivan Home Built 3 April 21st 05 02:10 PM
Color of spark plugs john smith Owning 5 March 2nd 04 03:08 AM
Spark plugs for ASH26E Ludovic Launer Soaring 4 February 3rd 04 07:56 PM
