Jonathan Goodish wrote:
: "Minimalist" is kind... I think it's a rather poor design, especially : for aircraft. It's right on-par with everything else designed at that point in time. Exactly the same gascolator is on my dad's 1939 Oliver 60 Row Crop tractor, except it has a clear glass bowl. They "ruggedized" it for aircraft useage by using an aluminum bowl... ![]() : The PMA part is aluminum, so it can't be that much heavier, and I hardly : think that this is an area where weight should take priority over safety. It looks like it's machined out of a solid piece, rather than cast. It looks heavier (and ironically much more expensive to produce). : I am going to call and talk to the STC owner and see what he tells me. : You are correct, it looks like there will need to be some plumbing to : get the drain to exit the cowling properly. If the latter can't be : accomplished gracefully, then this may not be a good solution after all. : The problem with the sump valve being left open is operator error and : not a design flaw. Personally, I scan all sump valves before flight to : ensure that there are no leaks. There might be a SB, but I am not aware : of any AD relating to this issue that applies to my aircraft, and we've : done a pretty comprehensive search of ADs over the years. It is and isn't operator error. Many of them (like mine) cannot be easily seen... it's tucked up within the cowling and is only accessed via a 1" hole. Also, you could scan for leaks all you want... if the gascolator has been drained of all fuel by sumping to a sample jar, it won't leak even if it's locked open. That's the substance of the AD/SB or whatever I heard. I would think you could get the drain with a 90 degree 1/8" NPT elbow and perhaps a small extension. My plane has a 45 degree on the stock bowl. If it's PMA'd for the PA-28, it *should* fit right in. If not it should have approved data (i.e. STC or standard AN part via AC43). -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
: That design is fine on a tractor, but is not so great on an aircraft.
: It's amazing what junk some of these aircraft manufacturers used (and : had certificated). They couldn't get away with the glass bowl, but they : did the minimum required to make it work to get the airplane : certificated. That's true, but there's history involved. Lots of manufacturers' parts were made cheaply as commodity parts at the time. Those were then grandfathered in to new designs, unless there was some reason to change them. IIRC, O-rings weren't even common until after WWII... the rubber washer in the gascolator is more old-school and predates WWII. An airplane is generally better built than a tractor, but a 1939 tractor and a 1939 Piper are more similar than different. Don't confuse "junk" with "old technology" or "inexpensive construction." They're not necessarily synonyms. I would (and apparently am) arging that the original gascolator is perfectly adequate unless abused (e.g. warped top, bad seals, stripped threads, etc). : It isn't necessary to drain the gascolator completely. In fact, when I : was a student pilot, I was taught to activate the fuel boost pump while : sumping, which would ensure that you couldn't accidentally drain the : gascolator. I think this is overkill and I no longer do this, but it's : probably not bad advice for a student pilot. OK, you got me. Draining the gascolator could be considered operator error as well. It doesn't have to be done, but some people do it anyway. In any event, since when has regulation made sense? (Since my gascolator is pressurized now with the fuel pump on, it *really* squirts out if you sample then) : I did call and talk to the guy this morning. He said that, in most : cases, the 90 degree fitting and extension usually does the job, but in : some cases, folks have remote mounted the valves. I don't want to : remote mount mine, so I might go take some measurements to make an : initial determination as to whether it will fit. I wouldn't relocate either... KISS. More parts, fittings, mounts to fail. : The bottom line is that if I elect to keep the Piper gascolator, I'm : stuck paying almost as much for just the bail wire as for the entire STC : gascolator unit. I'm sure that you can see why this is of such : interest, and I'm surprised that it hasn't received more attention. I agree completely for your situation. The original post seemed to imply a rampant and persistant problem with these old gascolators. I didn't know it was rampant. You may want to look at salvage yards. Also, since it *is* just a piece of wire, you can fabricate one yourself ("owner-fabricated parts") if your A&P/IA is OK with it. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Annual Report Final. "Long" | NW_PILOT | Owning | 20 | October 28th 04 07:20 PM |
Annual Report Final. "Long" | NW_PILOT | Piloting | 22 | October 28th 04 07:20 PM |
Fuel Transfer Placards | Ben Smith | Owning | 22 | October 16th 03 02:32 PM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
