Arrow Starter Problem
Old September 28th 05, 04:09 AM
Seth Masia
Agree with these posts. A likely culprit is the cabling, or specifically
corrosion in the cabling, from battery to engine compartment.
If there's plenty of voltage on the first few starts, and then the starter
won't turn, you've probably got a drain on the electrical system that's
bringing the battery down. Check for shorts or continuity through anything
that's not on the master switch -- panel clock? Gear motor?
My Comanche was running the battery down and we finally traced it to a
faulty microswitch in the landing gear -- the gear motor wasn't turning off
at the end of the gear travel, so it was pulling current even with the rotor
parked.
Remember that motors are less efficient when hot -- so your starter motor
will draw more current on a hot start even though the oil is thin.
Onward.
Seth
N8100R
"Ron Rosenfeld" wrote in message
On Tue, 27 Sep 2005 09:20:12 -0700, unicate wrote:
Writing for a friend with an Arrow that is having a recurring starter
problem. The battery has been charged and tested, everything else checks
out, and there is the right amount of voltage at the starter. It works
once or twice (in a row), then if left overnight, it won't restart (no
response from starter whatsoever). The starter has been replaced three
times with the same result -- starts right up on the first few tries,
but next day, it won't restart.
Anyone else experience this?
Thanks in advance.
Was the voltage at the starter checked while the engine was cranking?
Was the voltage at the starter checked when the starter was not
responding?
Were the starters examined after they failed to function (bench test) to
see WHY they malfunctioned?
Old September 28th 05, 06:10 AM
But everything else fed by the battery works just fine, even the next
day when the starter doesn't respond at all.
I don't know *all* the particulars, just thought someone may have had a
similar experience. The initial starter was bench-tested fine, put back
in, started a few times, then after a day, no response. Replaced with
"gear starter" with same results (initial start-up successful but no
response 24 hours later). Again, everything else tested and run by the
battery during preflight works fine.
your starter motor will draw more current on a hot start
Both successful and failing start-ups were done first thing in the
morning, after the airplane was parked all night.
Thanks to all for responding.
Prestolite Starter Sticking ShawnD2112 Owning 9 May 30th 05 11:12 PM
A problem in the Military ? Nick Jade Military Aviation 54 March 15th 04 07:59 PM
CF-105 AVRO Arrow etc. Ed Majden Military Aviation 4 February 22nd 04 07:00 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
