![]() "Bill Daniels" wrote Why would the fuel boil? Glycol/water coolant doesn't boil if the engine temps are normal. How are the temps going to stay normal, once the fuel has gotten up to engine operating temperature? Remember the premise that the skins will not get rid of the heat fast enough? Someone has proven it here before. The fuel will then get hotter and hotter, until it is boiling. The change of state may then keep the engine from melting down, at least until all of the fuel is gone. Using fuel as a coolant is a respected technique used by rocket engines and the SR-71. Rocket engines only use the fuel one time for cooling, and that is on the way into the combustion chamber. If it had to recirculate to keep the engine cool, the fuel would over pressure and over temp in a short period of time. The SR-71 does not use the fuel to cool the engine, but uses the fuel to cool the hot parts of the airframe, or in other words, redistribute the hot skin temps. It should also be noted that the fuel was very special, and only available at a few sites around the world. Are you planning on cooling your skins, and where are you going to get SR-71 fuel? Sorry, but your examples are not valid. If it worked, racers would do it, and so would some others. It does not work. those are my final words on the subject. See ya. -) -- Jim in NC |
![]() "Morgans" wrote in message ... "Bill Daniels" wrote Why would the fuel boil? Glycol/water coolant doesn't boil if the engine temps are normal. How are the temps going to stay normal, once the fuel has gotten up to engine operating temperature? Remember the premise that the skins will not get rid of the heat fast enough? Someone has proven it here before. The fuel will then get hotter and hotter, until it is boiling. The change of state may then keep the engine from melting down, at least until all of the fuel is gone. You know, I just don't buy the "skin radiators won't work" theory. The pre-war Schneider Cup Seaplane racers did use skin radiators to cool some really big engines. There are LOTS of reasons skin radiators weren't used on WWII fighters - bullet holes being one. Since then, piston aero engines have been air-cooled. About 10 years ago I did a crude experiment. The fuel tanks on a PA-28 are wet leading edge cells with only the wing skin between the fuel and the airstream. I filled the tanks on my Archer II from a fuel truck that had been sitting in the summer sun all day, measured the fuel temperature in the right tank and went flying in the cool evening air using the fuel in the left tank. 15 minutes later, after landing, I measured the right tank fuel temperature again. It was a LOT cooler than when I started. This is an experiment that anybody can do. Using the tank wetted area, the before and after fuel temperature, the OAT and the specific heat of AVGAS, I calculated the heat rejection of the tank as if it were used as a radiator. There was huge heat flow from the fuel in the tank to the airstream. It looked as if it would be larger than the heat rejection of the O-360 in the Archer's nose if the fuel temperature were as high as coolant would be. Now maybe if the fuel were at 200 F, the heating of the boundary layer would trip it to turbulent flow and create a lot of drag but I doubt that an Archer has much laminar flow anyway. If the fuel tank/radiator were in the propeller slipstream where it belongs there wouldn't be any laminar flow to trip. Bill Daniels |
![]() Bill Daniels wrote: You know, I just don't buy the "skin radiators won't work" theory. The pre-war Schneider Cup Seaplane racers did use skin radiators to cool some really big engines. There are LOTS of reasons skin radiators weren't used on WWII fighters - bullet holes being one. Since then, piston aero engines have been air-cooled. I don't either. A diesel fuel-cooled plant would NOT use raw fuel in its coolant passages. It would have a conventional glycol "primary loop", with a radiator-behind doors or (in front of) cowl flaps, a cabin heat exchanger ("heater core" in autoese), and an intercooler with fuel circulated through it and returned to tanks. It would be designed so the fuel loop could be shut off-bypassed- when the rad had its doors open as would be done when the aircraft was very low on fuel, or in high thermal load situations. At altitude (this is a turbodiesel and flies at high FL) the ambient temperature is very cold and the normal radiator could be blanked off largely or entirely. If the tanks are designed with a lot of surface area they will cool a large percentage of the engine's total heat rejection and additionally provide anti-icing. The main requirement as I see it is the system has to be default failsafe and provide single lever power control. Unless you want to make it a two person flight crew aircraft and haul a FE along. |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | November 23rd 03 11:43 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | October 29th 03 02:33 AM |
New WWII books from Germany | ArtKramr | Military Aviation | 0 | October 13th 03 12:54 AM |
