Change in AIM wording concerning procedure turn
Old September 30th 05, 03:57 PM
rps
Suppose I'm on an approach in which the IAP leads me to the inbound
course at the correct altitude (no radar), am I supposed to execute a
PT? That doesn't make sense to me. ATC would not have authorized
anyone else to be in that airspace so aircraft separation isn't a
problem and there is no need to lose altitude or change course so
obstacle clearance shouldn't be an issue.
Maybe there are no such approaches, or perhaps all such courses are
marked NoPT.
Old September 30th 05, 04:16 PM
Steven P. McNicoll
"rps" wrote in message
marked NoPT.
I believe you just answered your question.
Old September 30th 05, 04:36 PM
Gary Drescher
nk.net...
marked NoPT.
Even if the intention is to mark all such courses NoPT, there's always the
possibility that a NoPT gets omitted due to a charting error or a TERPS
design error. And the question arises in that case: is the PT required or
not? On one reasonable interpretation of the AIM's new wording, it's still
required; on the other reasonable interpretation, it's not.
--Gary
Old September 30th 05, 04:45 PM
Steven P. McNicoll
"Gary Drescher" wrote in message
not?
Not.
If it's required the requirement will be found in the FARs, and you will
find no FAR that requires it. The AIM is not regulatory.
Old September 30th 05, 04:55 PM
Gary Drescher
ink.net...
the possibility that a NoPT gets omitted due to a charting error or a
TERPS design error. And the question arises in that case: is the PT
required or not?
Not.
You'll find no FAR that explicitly requires performing a charted PT
*regardless* of whether or not the PT meets the TERPS criteria. That doesn't
make all the PTs optional, does it?
No, but in some cases it offers the only readily available definitive FAA
interpretation of key regulations. That's what it's trying to do in this
case, but the chosen wording is unfortunately ambiguous.
--Gary
Old September 30th 05, 05:21 PM
Ron Rosenfeld
On Fri, 30 Sep 2005 11:55:25 -0400, "Gary Drescher"
If the approach plates constitute an appropriate display of the contents of
FAA forms 8260, and if they indicate that the PT is mandatory, then that
*IS* an FAR (incorporated by reference into 14 CFR 97)
Old September 30th 05, 05:31 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
of
Can you provide an example of an approach plate with the statement "PT
MANDATORY", or something similar?
Old October 2nd 05, 11:14 PM
Steven P. McNicoll
doesn't make all the PTs optional, does it?
Of course not.
The regulation seems pretty clear to me in this case.
Old October 2nd 05, 11:38 PM
Gary Drescher
ink.net...
Of course not.
So then when is a PT mandatory, and by virtue of which regulation?
--Gary
Old September 30th 05, 06:44 PM
nk.net...
groups.com...
marked NoPT.
--Gary
The new AIM verbage is in error. The coordination was messed up, so
someone with a less than global view of it did some incorrect editing.
Following is part of an email sent yesterday by the person in the FAA
who understands this stuff and whose office should have issued any
change (no change was necessary, actually):
"We need to get AIM paragraph 5-4-9a fixed and clarify this in the IPG!
This is how the flying public is interpreting this and as you know, this
isn't the first time this has come up. The way it is written: 'The
procedure turn or hold in lieu of procedure turn is a required maneuver
when it is necessary to perform a course reversal' is way to open-ended
and leaves it up to the pilot to make this decision and the controller
to guess (or be surprised) what the pilot is doing."
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
