Crosswind Landings... But airspeed?
Old September 30th 05, 07:01 PM
Chris Reed
Stefan wrote:
And when exactly are you going to calculate all this? :-P
On downwind leg, and I won't do the full calculation. Something like 90
degrees= nil wind, 60 = half wind, 30=full headwind. In the example this
gives me +0, +5 or +10. Close enough.
If your glider floats well, like my Open Cirrus, then the extra few
knots is significant. If I land 10kt over the correct speed for the day,
I'll float more than twice as far after the roundout.
Old October 2nd 05, 03:18 PM
Jmarc99
"Chris Reed" wrote in message
If your glider floats well, like my Open Cirrus, then the extra few knots
is significant. If I land 10kt over the correct speed for the day, I'll
Hi Chris,
You wrote that something like 90 degrees= nil wind. So if someone
do a slip in the wind direction in order to sayt alligned with the runway
during the final leg, the pitch angle of the sailplane is somewhere greater
than supposed! In this case, with 90 degree wind, the sailplaine have
to travel a longer way through the air mass.
Though, the sailplane fly more faster than supposed, and the pilot
doesn't use much airbrake! Is that what effectively happen in that
wind condition?
Jmarc
Old October 3rd 05, 07:09 PM
Chris Reed
wind condition?
Jmarc
I'm not suer I understand the question properly.
My crosswind landing technique is to crab into wind, and then kick off
the drift after the roundout. This works fine for, say, a 10kt crosswind
at 90 degrees, and at that wind speed there's no real danger of wind shear.
However, if the wind is gusting 20kts or more at 90 degrees, that's
outside the demonstrated crosswind limits of my glider. Ideally, I
choose a better landing direction. If I had no choice (e.g. poor or late
field selection), then this would be one of those "interesting" landings
which test one's improvisational and piloting skills. I'd be using a
combination of crabbing and slipping, to give me less drift to kick
off,and I'd certainly add 10 kts or more to allow for gusts and wind
shear unless that seemed more dangerous than approaching at a slower speed.
I guess the point I was really trying to make is that if on every
landing you add extra speed for "safety", the result is that you never
learn to land with the minimum safe energy. This is a skill that I think
every XC pilot needs. However, in gusty or high winds, you have to allow
for the possibility of needing extra control authority or suddenly
losing 15kts airspeed through wind shear. So minimum safe energy
landings are for benign conditions.
Old October 4th 05, 02:31 AM
Jmarc99
greater
wind condition?
Jmarc
My crosswind landing technique is to crab into wind, and then kick off the
drift after the roundout. This works fine for, say, a 10kt crosswind at 90
I also prefer crabing than slipping!
I also agree that a little wind, coming from any direction, can't produce
dangerous wind shear. No wind means no real effective change in the
wind speed or wind direction.
outside the demonstrated crosswind limits of my glider. Ideally, I choose
a better landing direction. If I had no choice (e.g. poor or late field
selection), then this would be one of those "interesting" landings which
test one's improvisational and piloting skills. I'd be using a combination
of crabbing and slipping, to give me less drift to kick off,and I'd
certainly add 10 kts or more to allow for gusts and wind shear unless that
I guess the point I was really trying to make is that if on every landing
you add extra speed for "safety", the result is that you never learn to
No need for extra speed when there is no wind at all! I agree again
that is important to learn to land with the minimum safe energy..!
This is a skill that I think every XC pilot needs. However, in gusty or
high winds, you have to allow for the possibility of needing extra control
authority or suddenly losing 15kts airspeed through wind shear. So minimum
safe energy landings are for benign conditions.
The real point to talk in this thread is "how much" speed to add to
the 1.3 Vstall speed, depending on the wind speed? Especially if
the wind come from a side or the back!
All pilots seams to say that only the heading portion of the wind
should be took in care, when choosing the landing (circuit) speed.
Is someone might agree that a 15-20 knots wind, at low altitude
(like the final leg) may produce windshear that may lower the
the relative airspeed, instead of increasing it, even when the
wind come frome the back?
This is the real question. I think that very experienced glider
pilots, lurkink in this newsgroup, might have someting very
interesting to say about that!
Sure, the good thing is to land upwind, anyway! But, is that
right to reduce the speed to only 1.3 Vstall when you realize,
when doing the base leg, you're going to land tailwind?
Thanks Chris, for your interest to this question!
Jmarc...
Old October 4th 05, 02:33 PM
HL Falbaum
"Jmarc99" wrote in message
runway
greater
wind condition?
Jmarc
shear.
speed.
control authority or suddenly losing 15kts airspeed through wind shear.
So minimum safe energy landings are for benign conditions.
Jmarc..
One answer is based on understanding what the "reported wind" really means.
15kt gusting to 25 kt means that the average speed over time (I have
forgotten the exact time interval but about 30 to 60 sec) is 15kt. If peak
gusts are 25kt, then that means it can fall as low as 5kt on the average,
and for some moments can be 0kt. The gusts come from turbulence, and can
therefore come from *any* direction. The danger is not so much the 25kt gust
but the 5kt lull. Hence the advice to add the gust differential to the
approach speed. Some advise "half the wind plus half the gust
differential"--more or less the same result. What is needed is to remain
above stall speed until touchdown! Thankfully, the wind is much less very
close to the ground---3-4 ft (1 meter). My glider stalls at 38kt --1.3 Vs
is therefore ~ 50kt. So, with a "negative" (opposite direction) gust, I
would be very close to stall without the extra velocity.
As to the tailwind question---the wing only knows airspeed. But the landing
field does not move with the wind, so the ground speed is eventually
important. The pilot will be tempted to slow at this point as the ground
speed seems high. Then there is the loss of control issue then the glider is
rolling on the ground, but has little aerodynamic control due to low
airspeed. Finally there is a wind shear issue at about 200 ft. If you are
landing downwind, you will descend into a decreasing tailwind, and inertial
forces will give you an increase in airspeed. It is best to be on final
approach before descending into this shear, which BTW, always exists. It is
just the magnitude that varies. This is so speed adjustments can be made
without the complications of turning--i.e. raised stall speed, increased
workload, etc.
Sooner or later, you will have to slow down in order to land and stop. So
fly the "no wind" approach speed and add the gust differential, until it is
time to roundout and land. Use the brakes if the tailwind is leading to a
imminent loss of control.
Happy Landings
Hartley Falbaum
ASW27B KF USA
Old October 4th 05, 07:30 PM
Jmarc99
"HL Falbaum" wrote in message
means. 15kt gusting to 25 kt means that the average speed over time (I
have forgotten the exact time interval but about 30 to 60 sec) is 15kt. If
peak gusts are 25kt, then that means it can fall as low as 5kt on the
average, and for some moments can be 0kt. The gusts come from turbulence,
and can therefore come from *any* direction. The danger is not so much the
25kt gust but the 5kt lull. Hence the advice to add the gust differential
to the approach speed. Some advise "half the wind plus half the gust
As you said, I totally agree that "The gusts come from turbulence, and can
therefore come from *any* direction". So, the aircraft may also come
"close to stall without the extra velocity" with a tailwind situation
on the final leg!
But the rule says to add nothing in a tailwind situation? Probalbly because
the decreasing windspeed when closer to the ground will effectively produce
an increasing airspeed to the aircraft. But this doesn't looks right to me,
to fly just 1.3 Vstall on the base leg and the final leg, just because I'm
going
to land tailwind!
Am I right to say that extra speed stands for a security reason. It is not
simply to compensate the facing wind component. Otherwise, a pilot
may simply use less airbrake to get the same glidepath on the final leg!..
Thought, why not adding the extra knots to the 1.3 Vstall, whatever the
wind direction? Even tailwind?
As the glider come closer to the runway, still plenty of time to reduce
the airspeed before landing!
landing field does not move with the wind, so the ground speed is
eventually important. The pilot will be tempted to slow at this point as
the ground speed seems high. Then there is the loss of control issue then
the glider is rolling on the ground, but has little aerodynamic control
due to low airspeed. Finally there is a wind shear issue at about 200 ft.
If you are landing downwind, you will descend into a decreasing tailwind,
and inertial forces will give you an increase in airspeed. It is best to
be on final approach before descending into this shear, which BTW, always
exists. It is just the magnitude that varies. This is so speed adjustments
can be made without the complications of turning--i.e. raised stall speed,
increased workload, etc.
is time to roundout and land. Use the brakes if the tailwind is leading to
a imminent loss of control.
Sure!
Happy Landings
Hartley Falbaum
ASW27B KF USA
Old October 4th 05, 07:54 PM
HL Falbaum
on the final leg!
because
produce
me,
going
to land tailwind!
not
Yes! Exactly the point I was trying to make in a long-winded fashion in
the paragraph below.
adjustments can be made without the complications of turning--i.e. raised
stall speed, increased workload, etc.
So--here is the conclusion---for all situations
fly the "no wind" approach speed *and* add the gust differential, until
it is time to roundout and land. Use the brakes if the tailwind is
leading to a imminent loss of control.
Sure!
Happy Landings
Hartley Falbaum
ASW27B KF USA
Hartley Falbaum
A new direction for an old thread: Crosswind landings [email protected] Soaring 96 March 4th 05 01:22 AM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 12:08 AM
Strong crosswind landings! Toks Desalu Piloting 12 April 19th 04 07:43 PM
