"wright1902glider" wrote in message
oups.com... Suggestions? Methods? Tools? Harry............. Drilling in a Vee block with a clamp is, of course, the way to hold the tubing. On larger tubing, lining up the holes by placing a piece of angle iron on the tube and using the edge of the iron as a straight edge to scribe a line works pretty well. When I was a nipple twister in the pipe shop at Todd's shipyard, we had some clamps made especially for operations like this. It was a two-bolt pipe clamp that bolted tightly around the tube. Welded to one half of the clamp was a short piece of 1" x 1" angle iron. It was welded across the diameter of the tube and parallel to the clamp. With the tubing clamped in a drill press (or in a tubing bender), a level was placed on the angle iron and the clamp rotated until the bubble was in the center. The clamp was tightened at that point and either the first hole drilled or the first bend made. Then the tubing was relocated for the next hole (or bend). This time, you'd rotate the tubing until the level showed that in was in the same orientation as the previous setup. Clamp the tubing in place, drill or bend and move on to the next. You could also rotate the tube from one operation to the next by any degree if you used an adjustable degree level. Regards, Rich S. |
Fixing screw holes in fabric | Brian Huffaker | Home Built | 4 | May 21st 05 02:16 AM |
Any sources of thin walled 4130 tubing in northern CA? | mike | Home Built | 3 | February 6th 05 03:20 PM |
source for aluminum tubing with rounded corners? | Kyler Laird | Home Built | 3 | June 1st 04 03:07 PM |
the complete minute by minute timeline on 911 | Krztalizer | Military Aviation | 27 | January 27th 04 04:35 PM |
Winching: Steel vs. Plasma | Bob Johnson | Soaring | 10 | August 12th 03 05:41 PM |
