![]() "Ron Rosenfeld" wrote in message ... On Sat, 01 Oct 2005 07:58:13 GMT, "Brad Salai" wrote: Are you saying that if the form (approach plate?) says no PT, then no PT is required, which I understand and agree with, or are you saying that if the form is silent, then a PT is required in all cases, which I'm less sure of? I should only speak with regard to Jepp charting conventions as those are the approach plates I use. If a route or segment states NoPT, then no procedure turn is required OR authorized. If you want to do a procedure turn, you must obtain ATC permission. If a procedure turn is charted, then it is required unless one of the previously discussed exceptions apply (e.g. NoPT; vectors to final; timed approaches). If a procedure turn is NOT charted, then it is NOT authorized. I looked at random at a bunch of NOCA forms, and there are lots of instances of approaches from IAF's that clearly say no PT. These seem all to be situations where I would say (based on pilot judgment) that a course reversal is not required. There are also lots of examples, most, or all on courses outbound on the final approach heading, that show a PT barb, which I take as indicating that a PT is mandatory. on the new GPS approaches where the heading into the fix is 90 degrees, there are indications that no PT is required, other than that, I couldn't find any indication in ambiguous situations (90 degrees or more), of whether a PT is required or not. It looks to me as if, other than the pretty clear case where you are outbound on the final approach heading, that they never indicate when a PT is required, only when it is not. That means, I think, that you are going to have to determine whether "a course reversal is required," to know whether you need to make a PT. I believe the determination of "course reversal required" is to be made by the procedure designer, and not the pilot. Is there a definition somewhere of what a course reversal is, or even better, when a course reversal is required? TERPS (I think it's 8260.3 and 8260.19 or something like that) If you happen to have it, or can get it, look at the VOR RWY 13 approach to ACY (Atlantic City). A holding pattern is depicted at the IAF, but there is no guidance as to when it should be used. Doesn't that mean that the pilot needs to determine based on his heading into the IAF whether a course reversal is required, and if it is, then he has to do a PT, either a conventional PT, or a course reversal by way of the depicted hold? Or are you saying that you need to enter the hold from all directions, go around at least once, and then continue in, in which case, isn't the "when a course reversal is required" language redundant? Since the racetrack pattern is charted, the procedure turn must be flown as charted (e.g. the type of turn and where to start it, in this instance, is NOT pilot choice). Again, according to Jepp charting conventions, this PT would have to be flown unless you were on radar vectors to the final approach course (or if there were timed approaches going on). I'm not familiar with that area, or how ATC works there, but I would expect that radar coverage would be pretty good there and, unless there's some traffic related reason off to the NW and not on the approach chart, that you would be getting radar vectors to final if you were approaching from the NW (or maybe even from other directions). And there may be TERP's related reasons for that required course reversal, also. The only charted course to the IAF is from ACY VOR with an MEA of 1900'; the MSA for that sector is 2100'. If you were to cross BURDK at either of those altitudes, in order to execute a straight-in approach, you would exceed the maximum TERPS allowed descent gradient of 400 ft/nm for a straight-in approach. (1900-75)/4.5 = 405.6 ft/nm. So, the procedure designer determined that a course reversal was required in order to publish straight-in minimums. I wouldn't have guessed it from the language, but what you say makes a lot of sense, and especially with the approach gradient issue, seems like the safest way, so I at least will do it that way. Just to be certain what you mean, coming in from the NW, straignt in, cross BURDK, enter the hold and decend from 1900 to 1600 when established on the inbound leg before reaching BURDK the second time? All this assumes no radar vectors. Thanks. Brad |
On Sat, 01 Oct 2005 13:33:03 GMT, "Brad Salai"
wrote: I wouldn't have guessed it from the language, but what you say makes a lot of sense, and especially with the approach gradient issue, seems like the safest way, so I at least will do it that way. Just to be certain what you mean, coming in from the NW, straignt in, cross BURDK, enter the hold and decend from 1900 to 1600 when established on the inbound leg before reaching BURDK the second time? All this assumes no radar vectors. Well, coming from the NW there's no charted route until you get to BURDK of which I am aware. So, unless ATC can clear you to a lower altitude, your minimum IFR altitude would be controlled by 91.177 (ii) "In any other case, an altitude of 1,000 feet above the highest obstacle within a horizontal distance of 4 nautical miles from the course to be flown." 1900 would probably be safe once you got to the area of the procedure turn, but that's not precisely charted. If I were doing this from the NW, non-radar, I would probably maintain at or above the MSA, which is a charted altitude, until BURDK; then descend to 1900 outbound and 1600 inbound. (1900 might be both safe and legal in the area to the NW that is not on the approach plate, but I'd have to study sectionals to be sure). Having said that, your clearance from ATC should give you the information. Coming from the NW, it should go something like "Maintain at or above xxxx ft until (some_fix); cleared for the VOR Rwy 13 approach". If you are doing this non-radar, your clearance will likely be to ACY and not to BURDK. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Brad Salai" wrote in message ... Just to be certain what you mean, coming in from the NW, straignt in, cross BURDK, enter the hold and decend from 1900 to 1600 when established on the inbound leg before reaching BURDK the second time? All this assumes no radar vectors. What ATC clearance are you following when you're coming in to BURDK from the northwest? |
GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 04:51 PM |
Required hold? | Nicholas Kliewer | Instrument Flight Rules | 22 | November 14th 04 01:38 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
IFR in the 1930's | Rich S. | Home Built | 43 | September 21st 03 01:03 AM |
