You're certainly right about ground clearance for deep snow. I don't
off-road in the Subaru -- I have skis for that. I do however drive long distances in blizzards. Last Xmas I caught a storm at Tahoe, skied two days of powder in it, surfed it across to Utah, skied pow at Alta, surfed across to Steamboat and skied two more days of Colorado pow. One storm, five days of untracked powder, 1000 miles of snowpacked roads at night, and never saw the sun. And never got sideways in the Subaru. My idea of heaven. Seth "Matt Whiting" wrote in message ... Seth Masia wrote: You'd better look up "coefficient of friction" in a physics text. I've driven plenty of rented SUVs in snow, in mountain rangers across the continent and around the world -- and none of them handles, goes or stops as well as my 98 Subaru with IRS and Michelin snow tires. I've driven a number of Subarus and also trucks and SUVS. My K1500 will go through deep, wet snow much better than any Subaru. That simple reason is ground clearance. I have about twice what a Sub has. If you really believe that this doesn't make a difference, then your experience is much more limited than you claim. Sure, in 5" of snow, the Sub will perform as well or better. But in 12" of snow, the tables turn. My truck is barely dragging at that point, but the Sub is pushing 5" or so of snow. Matt |
Morgans wrote:
"Paul Tomblin" wrote Only twice as heavy and more susceptable to side winds. twice as heavy (which they really are not) means more weight on the wheels, which give a higher coefficient of friction, plus the fact that they have bigger tires. It also helps if you don't drive faster than your ability to stop for the conditions. More weight means more total friction all else being equal, but it doesn't, to a first order, change the coefficient of friction. That is largely a function of the materials that are in contact. The total friction force is the coefficient of friction times the normal force (weight in this case) clamping the two surfaces together. If you don't like SUV's, OK, but this is a stupid argument to base the cons on. That's a fact. My pickup is blown around much less in cross winds than are my minivans. Matt |
... More weight means more total friction all else being equal, but it doesn't, to a first order, change the coefficient of friction. That is largely a function of the materials that are in contact. The total friction force is the coefficient of friction times the normal force (weight in this case) clamping the two surfaces together. Actually, the determining factor is tire pressure. Now, many trucks and SUVs use higher tire pressures than what is normally found in passenger cars, but some are the same or lower. The actual weight of the vehicle isn't that important, assuming adequate brakes (which, when on snow or other low-friction surfaces, is the case for basically every vehicle), as long as the tire pressure is sufficiently high. As with most generalizations, one cannot simply say "all SUVs are bad", no more than one can say "all passenger cars are good". As far as I'm concerned, all you on the pro-SUV of this debate just got baited into one of the classic stupid debates. You might as well be arguing Ford vs Chevy or high-wing vs low-wing. The people claiming there's no valid reason for driving an SUV don't have a clue, and the pro-SUV folks are unlikely to change that. At the same time, anyone defending ALL SUVs in ALL situations is just as lacking in clues (not that I see much of that, but still...) I feel dumb even bothering to post to this topic...but too many posts have gone by arguing that weight matters, without a single mention of what really affects the friction between the tire and driving surface: tire pressure. Pete |
Peter Duniho wrote:
"Matt Whiting" wrote in message ... More weight means more total friction all else being equal, but it doesn't, to a first order, change the coefficient of friction. That is largely a function of the materials that are in contact. The total friction force is the coefficient of friction times the normal force (weight in this case) clamping the two surfaces together. Actually, the determining factor is tire pressure. Now, many trucks and SUVs use higher tire pressures than what is normally found in passenger cars, but some are the same or lower. The actual weight of the vehicle isn't that important, assuming adequate brakes (which, when on snow or other low-friction surfaces, is the case for basically every vehicle), as long as the tire pressure is sufficiently high. How so? As with most generalizations, one cannot simply say "all SUVs are bad", no more than one can say "all passenger cars are good". As far as I'm concerned, all you on the pro-SUV of this debate just got baited into one of the classic stupid debates. You might as well be arguing Ford vs Chevy or high-wing vs low-wing. The people claiming there's no valid reason for driving an SUV don't have a clue, and the pro-SUV folks are unlikely to change that. At the same time, anyone defending ALL SUVs in ALL situations is just as lacking in clues (not that I see much of that, but still...) I feel dumb even bothering to post to this topic...but too many posts have gone by arguing that weight matters, without a single mention of what really affects the friction between the tire and driving surface: tire pressure. That is because you aren't correct. Tire pressure only has a significant impact on very soft surfaces such as sand, where the extra surface area helps with flotation. In most snow, it makes little difference. Matt |
![]() "Matt Whiting" wrote More weight means more total friction all else being equal, but it doesn't, to a first order, change the coefficient of friction. Correct. I got my terminology wrong. What you said is what I meant. I have not taken any physics in a long time, and that is a *Good Thing*, to me! g -- Jim in NC |
(Paul Tomblin) wrote: Too bad they don't give you the ability to stop when it snows. no worse than other vehicles. Only twice as heavy many cars weigh more than my SUV. and more susceptable to side winds. like mini-vans? Seriously, there is no great secret to driving in the snow. Take it easy, take it slow, allow plenty of room. This doesn't change one bit whether it's a regular car or an SUV. -- Bob Noel no one likes an educated mule |
"Bob Noel" wrote in message
Seriously, there is no great secret to driving in the snow. Take it easy, take it slow, allow plenty of room. This doesn't change one bit whether it's a regular car or an SUV. Except if you're going uphill. Go hard keep your foot in it. Ice racing is a cheap sport and an eye opener. moo |
![]() "Paul Tomblin" wrote in message ... In a previous article, "Morgans" said: and their stuff, kids friends, and other general stuff. Four wheel drive, so you can still go when it snows, or you park in the wet grass, and get ^^^^^^^^^^^^^^^^ Too bad they don't give you the ability to stop when it snows. Actually, with anti-lock braking, they stop very well. Common sense goes a long way, in driving. -- Jim in NC |
On 2005-10-01, Paul Tomblin wrote:
In a previous article, "Morgans" said: and their stuff, kids friends, and other general stuff. Four wheel drive, so you can still go when it snows, or you park in the wet grass, and get ^^^^^^^^^^^^^^^^ Too bad they don't give you the ability to stop when it snows. Justice was served a couple of years ago in the Cottonwood Canyons (I don't remember which one, I think it was the one going to Brighton). Friends and I were carefully going up the canyon in a Volkswagon Jetta TDi with snow chains. The guy in the 4x4 behind us was obviously getting impatient, and went roaring by us. Half a mile later, we passed him - as he was trying to extract his truck from a ditch. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Wow - heard on the air... (long) | Nathan Young | Piloting | 68 | July 25th 05 06:51 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
