Then again, a Piper Arrow generally won't do so either (all the Arrows I
find have had a fairly pronounced and slow phugoid oscillation. In fact, I find the Beech Bonanza a lot less work to fly IFR than an Arrow because the Bonana flies better hands-off). Then again, the Bonanza has a side-side tail wiggle that other airplanes do not. And nothing short of a yaw damper will stop it. |
On Sat, 01 Oct 2005 17:11:20 GMT, john smith wrote:
Then again, a Piper Arrow generally won't do so either (all the Arrows I find have had a fairly pronounced and slow phugoid oscillation. In fact, I find the Beech Bonanza a lot less work to fly IFR than an Arrow because the Bonana flies better hands-off). Then again, the Bonanza has a side-side tail wiggle that other airplanes do not. And nothing short of a yaw damper will stop it. Yah, but if the pilot doesn't sit in the back seat he'll never no it's there. I've never noticed it on calm days either. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On 2005-10-01, john smith wrote:
Then again, a Piper Arrow generally won't do so either (all the Arrows I find have had a fairly pronounced and slow phugoid oscillation. In fact, I find the Beech Bonanza a lot less work to fly IFR than an Arrow because the Bonana flies better hands-off). Then again, the Bonanza has a side-side tail wiggle that other airplanes do not. And nothing short of a yaw damper will stop it. I've not found the Bonanza waggle to be something that makes it not fly hands-off: it's short period, doesn't result in a net course change and not particularly severe (well, unless you're in the back seat). -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
On Mon, 03 Oct 2005 08:24:41 -0000, Dylan Smith
wrote: On 2005-10-01, john smith wrote: Then again, a Piper Arrow generally won't do so either (all the Arrows I find have had a fairly pronounced and slow phugoid oscillation. In fact, I find the Beech Bonanza a lot less work to fly IFR than an Arrow because the Bonana flies better hands-off). Then again, the Bonanza has a side-side tail wiggle that other airplanes do not. And nothing short of a yaw damper will stop it. I've not found the Bonanza waggle to be something that makes it not fly hands-off: it's short period, doesn't result in a net course change and not particularly severe (well, unless you're in the back seat). It does tend to raise the "barf factor" a tad, but it does that in the straight tails too. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
