![]() wrote Somehow this same barebones functional look reminded me a bit of the Mosquito helicopter, also featured on the same site: I didn't see what the engine was on the heli, but if you know what it is, do some calculations. Figure the wattage for the gas engine heli, then convert it into amp hours for the length of time that you want to fly, then figure out how much weight of batteries you will have to carry. My bet is that the batteries will weigh too much, and be too expensive. I HATE being a pessimist! -- Jim in NC |
("Morgans" wrote)
My bet is that the batteries will weigh too much, and be too expensive. I HATE being a pessimist! Diesel turning a generator? Montblack |
![]() "Montblack" wrote Diesel turning a generator? And this is supposed to be saving weight? g Why not just turn the rotor with the diesel? Too obvious? -- Jim in NC |
Morgans wrote:
"Montblack" wrote Diesel turning a generator? And this is supposed to be saving weight? g Why not just turn the rotor with the diesel? Too obvious? It *might* be possible that diesel-electric system would be lighter than pure electric or pure diesel. A small diesel could be optimised to run continuously at its most economical RPM, producing only a little more electricity than needed to drive the rotor in level flight. For additional power, electricity from the battery would also drive the rotor. When descending, the battery gets charged faster. |
![]() "Frank van der Hulst" wrote It *might* be possible that diesel-electric system would be lighter than pure electric or pure diesel. I'm from Oklahoma. Show me! A small diesel could be optimised to run continuously at its most economical RPM, It would already have to have a gearbox for a heli, so it can run whatever RPM you want. An electric motor would also have a gearbox. Yes I know, there are low speed electric motors, but they are huge and heavy. producing only a little more electricity than needed to drive the rotor in level flight. There will always be losses, driving a generator, then a motor. You will have to have at least 10% more power output by the diesel motor, just to break even, and more than that to charge batteries. So lets see, we have to have a gearbox both ways, no change in weight between the two. We will have to have a bigger diesel to take care of losses, so penalty goes to electric. We would have to have batteries for electric, so more penalty for electric. Since our electric has gotten heavier, we will have to have a bigger engine, and more fuel, so BIG penalty for electric. For additional power, electricity from the battery would also drive the rotor. When descending, the battery gets charged faster. What you are talking about is like an autorotation. The blades in an autorotation have to go to negative pitch, just to make the blades maintain RPM, and to get more power to generate electricity than a plain autorotation, they would have to be at even more negative pitch. You would have to descend so fast to get the rotor to produce electricity, your passengers would freak! -- Jim in NC |
Morgans wrote:
"Frank van der Hulst" wrote A small diesel could be optimised to run continuously at its most economical RPM, It would already have to have a gearbox for a heli, so it can run whatever RPM you want. An electric motor would also have a gearbox. Yes I know, there are low speed electric motors, but they are huge and heavy. The whole point of these wheelmotors is that they are smaller than equivalent DC motors, and turn at low speeds. The numbers I've seen are 110-150rpm. See http://www.smartmotor.no/products/quiet_traction/ -- this talks about wheelmotors in relation to wheelchairs, and claims twice the efficiency over traditional DC+gearbox systems. You could think of the generator/motor combination as an electrical rather than mechanical gearbox. Another interesting site is http://www.killacycle.com/ -- an electrically powered drag bike that gets 9.450 seconds @152.07 mph over the 1/4 mile. Still a long way from the 5.895 @ 238.22 nitro powered world record though. producing only a little more electricity than needed to drive the rotor in level flight. There will always be losses, driving a generator, then a motor. You will have to have at least 10% more power output by the diesel motor, just to break even, and more than that to charge batteries. So lets see, we have to have a gearbox both ways, no change in weight between the two. We will have to have a bigger diesel to take care of losses, so penalty goes to electric. We would have to have batteries for electric, so more penalty for electric. Since our electric has gotten heavier, we will have to have a bigger engine, and more fuel, so BIG penalty for electric. But the diesel only ever runs at one speed... it's most economical. I'm assuming that there will be significant weight savings in that. I may be wrong in that assumption. I do know that having a car petrol engine which can potentially deliver a lot more horsepower means that it uses more fuel at lower horsepower output. Maybe this relationship doesn't apply to diesels. For additional power, electricity from the battery would also drive the rotor. When descending, the battery gets charged faster. What you are talking about is like an autorotation. No. I'm saying that when descending, less power from the engine/generator goes to the rotor, leaving more to go to the battery. |
![]() Morgans wrote: wrote SNIP I HATE being a pessimist! -- Jim in NC Then stop. It's a simple 12 step program... :-) -Matt |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
OT but very funny after some of the posts we have had of late. | Mycroft | Military Aviation | 1 | August 8th 03 10:09 PM |
Electric whine in the light circuit - Help | Victor J. Osborne, Jr. | Owning | 1 | July 29th 03 11:36 PM |
