Try this link for info:
http://www.sjvls.org/bens/bf010cs.htm J. Severyn KLVK "Dick" wrote in message t... Was talking with some WW2 guys who remembered the use of 10 gauge shotgun shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? |
It's a Coffman, or Eclipse starter. Gun gases spun a wheel, which
could also be spun by hand or foot treadle, an electric motor, or other means in some versions. They were not totally unique to aircraft, a few were used in military vehicles and other oddball applications. They were generally junked and replaced by direct drive electric starters when they became available. Cartridge start was also used on jets. Various bombers and fighters have had cartridge start, as did some civilian aircraft. Boeing 727s sometimes had cartridge start on the center engine (don't ask me how I know...) so the aircraft could start if it diverted to a field with no start cart. You had one shot, then you called out the recovery team. I think United had a Lear for things like that, otherwise, another revenue aircraft had to be internal-chartered, if no other airline had a maintenance presence on field. |
Cool, I knew/heard about these cartridge starters, now I know about the
third engine on the 727. Thanks for the additional info. Bryan "The Monk" Chaisone |
The British Camberra used them. It's a high altitude spy plane that we licensed the design for, so that we could turn it into the U-2. One of the changes we made was to get rid of the cartridge start, because the huge mass of black smoke was considered "not high tech." |
In article .com,
"jmk" wrote: Cartridge start was also used on jets. The British Camberra used them. It's a high altitude spy plane that we licensed the design for, so that we could turn it into the U-2. One of the changes we made was to get rid of the cartridge start, because the huge mass of black smoke was considered "not high tech." Canberra and U-2 were totally separate aircraft! U-2 was a single-engine, indigenous Lockheed design, based on high-performance sailplanes of the day. Canberra was a twin-engined British design for a high-altitude bomber. The Martin Co. modified the Canberra into the B-57; the special reconnaisance aircraft was the "RB-57D/E," which looked somewhat like the B-57, but with much longer wings and different engines. |
I understand that the U2 was based on the F104 Starfighter.
Seemed unlikely to me too but then I compared the Fuselages. |
![]() Orval Fairbairn wrote: snip Canberra was a twin-engined British design for a high-altitude bomber. The Martin Co. modified the Canberra into the B-57; the special reconnaisance aircraft was the "RB-57D/E," which looked somewhat like the B-57, but with much longer wings and different engines. That's because it was a B-57 with much longer wings and different engines. Actually there were two variants: one had four engines, two monsters and two auxilliary engines IIRC. |
First off, you are right. Don't know where I got THAT confused. We
worked on a TR-3 NASA aircraft (nothing to do with the "new" TR-3 triangle aircraft). back in the late 70's, which was also a variant. FWIW, did find a picture of a Canberra starting up. http://www.ramm.shacknet.nu/robant/a...to%20leave.JPG |
jmk wrote:
First off, you are right. Don't know where I got THAT confused. We worked on a TR-3 NASA aircraft (nothing to do with the "new" TR-3 triangle aircraft). back in the late 70's, which was also a variant. FWIW, did find a picture of a Canberra starting up. http://www.ramm.shacknet.nu/robant/a...to%20leave.JPG The first time I ever saw a cart start up close was an F-4E in a tab V shelter, I never could remember what tab V stood for, and was quite impressed. Just before start we vacated the tab V and watched from outside. A jet of flame and smoke appeared under the left engine and within a couple of seconds the shelter filled up with dense black smoke which obscured everything from the cockpits on back. When the engine was up and running the smoke cleared in a couple of seconds. One thing I wish I could see would be a B-52 cart starting all eight engines at once. Dan, U.S. Air Force, retired |
Toronto Area Glider Pilot Ground School Starts Thu. February 24, 2005 | Ulf | Soaring | 0 | February 3rd 05 06:16 PM |
EAA Airventure 2005 Starts on a Monday | Fitzair4 | Home Built | 9 | September 21st 04 03:04 AM |
Air Force Raptor fighter starts operational trials, By John J. Lumpkin | Otis Willie | Military Aviation | 0 | May 1st 04 10:18 PM |
Training starts with aerospace physiology | Otis Willie | Military Aviation | 2 | December 4th 03 11:03 AM |
Toronto Area Glider Pilot Ground School Starts Wed. November 19 | Ulf | Soaring | 0 | November 1st 03 11:09 AM |
