![]() "Jerry Springer" wrote in message ... wrote: You guys are giving bad advice. I fly a Glastar with an O-320 E2A in it. I have flown dozens of hours at density altitudes above 15000 ft. And that is with the plane loaded to GW. I agree, I have flown my RV-6 at 15000 ft several times when I had a O-320 E2D on it and it was still climbing with no problem. I used to fly across the mtns. in my Tripacer at altitudes of 14,500. John Ammeter something does not sound right that you could not get your RV-6 above 13,500. Jerry Someone with 150 hp and a cruise prop might not be able to generate a whole lot of rpm and therefore power at that altitude. It goes back to the compromises you make with a fixed pitch prop. Also, it depends on how heavily loaded the RV-6 was. I list my 160 hp, fixed pitch RV-6's gross weight at 1675 lb, and the climb and altitude performance really suffer with the last 50 lbs or so. KB |
that sounds like my situation...
John Kyle Boatright wrote: Someone with 150 hp and a cruise prop might not be able to generate a whole lot of rpm and therefore power at that altitude. It goes back to the compromises you make with a fixed pitch prop. Also, it depends on how heavily loaded the RV-6 was. I list my 160 hp, fixed pitch RV-6's gross weight at 1675 lb, and the climb and altitude performance really suffer with the last 50 lbs or so. KB |
Plane is telling you to skip desert!
"John Ammeter" wrote in message ... that sounds like my situation... John Kyle Boatright wrote: Someone with 150 hp and a cruise prop might not be able to generate a whole lot of rpm and therefore power at that altitude. It goes back to the compromises you make with a fixed pitch prop. Also, it depends on how heavily loaded the RV-6 was. I list my 160 hp, fixed pitch RV-6's gross weight at 1675 lb, and the climb and altitude performance really suffer with the last 50 lbs or so. KB |
It might have been the payload.... I know we were at or slightly over
gross... The stick had a very light "feel" to it, like we were close to the stall.. John Jerry Springer wrote: wrote: You guys are giving bad advice. I fly a Glastar with an O-320 E2A in it. I have flown dozens of hours at density altitudes above 15000 ft. And that is with the plane loaded to GW. I agree, I have flown my RV-6 at 15000 ft several times when I had a O-320 E2D on it and it was still climbing with no problem. I used to fly across the mtns. in my Tripacer at altitudes of 14,500. John Ammeter something does not sound right that you could not get your RV-6 above 13,500. Jerry |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 07:13 PM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Motorgliders and gliders in US contests | Brian Case | Soaring | 22 | September 24th 03 12:42 AM |
