Change in AIM wording concerning procedure turn
Old October 3rd 05, 01:23 AM
Ron Rosenfeld
On Sun, 02 Oct 2005 22:41:08 GMT, "Steven P. McNicoll"
"Ron Rosenfeld" wrote in message
If a procedure turn is charted, then it is required unless one of the
previously discussed exceptions apply (e.g. NoPT; vectors to final; timed
approaches).
Where in the FARs did you find that requirement?
To elaborate, it is in the Jepp interpretation of the FAA published
approach procedure. These procedures are regulatory by virtue of 14 CFR 97
and must be followed by virtue of 14 CFR 91
I believe the determination of "course reversal required" is to be made by
the procedure designer, and not the pilot.
Why?
Because the requirement is noted in TERPS which is used to design the
approach.
Old October 3rd 05, 01:35 AM
Steven P. McNicoll
97
Then it appears that Jepp misinterpreted.
approach.
The TERPs requirements apply only to the design of the procedure.
Old October 3rd 05, 02:20 AM
Ron Rosenfeld
On Mon, 03 Oct 2005 00:35:29 GMT, "Steven P. McNicoll"
97
Since 14 CFR 97 states that the SIAP's are included by reference, it would
seem that the regulatory nature of these SIAP's is pretty clear.
approach.
And the procedures based on TERPs are regulatory.
Steve,
Myself, Jepp, as well as FAA published legal opinion all agree that a PT
must be flown if the pilot is cleared for a SIAP which includes a PT, and
for which one of the 91.175 exceptions is not present.
SIAP's ARE regulatory. They are included, by reference, in 14 CFR 97.
It is certainly your right to disagree with Jeppesen's interpretation, and
with the FAA Assistant Chief Counsel Regulatory Division's interpretation.
Myself, I will choose to rely on their opinions, and encourage others to do
the same.
Nov. 28, 1994
Mr. Tom Young, Chairman
Charting and Instrument Procedures Committee
Air Line Pilots Association
535 Herndon Parkway
Herndon, VA 22070
Dear Mr. Young,
.... A SIAP may or may not prescribe a procedure turn based on the
application of certain criteria contained in the TERPs. However, if a SIAP
does contain a procedure turn and ATC has cleared a pilot to execute the
SIAP, the pilot must make the procedure turn when one of the conditions of
Section 91.175(j) is not present.
If you have any questions regarding this matter, please contact Patricia
R. Lane, Manager, Airspace and Air Traffic Law Branch, at (202) 267-3491.
Sincerely,
/s/
Patricia R. Lane
for Donald P. Byrne
Regulations Division
Title 14: Aeronautics and Space
PART 97—STANDARD INSTRUMENT APPROACH PROCEDURES
Subpart C—TERPS Procedures
§ 97.20 General.
(a) This subpart prescribes standard instrument procedures and weather
takeoff minimums based on the criteria contained in FAA Order 8260.3, U.S.
Standard for Terminal Instrument Procedures (TERPs), and other related
Orders in the 8260 series that also address instrument procedure design
criteria.
(b) Standard instrument procedures and associated supporting data adopted
by the FAA are documented on FAA Forms 8260–3, 8260–4, 8260–5. Weather
takeoff minimums are documented on FAA Form 8260–15A. These forms are
incorporated by reference. The Director of the Federal Register approved
this incorporation by reference pursuant to 5 U.S.C. 552(a) and 1 CFR part
51...
Old October 3rd 05, 10:32 AM
Steven P. McNicoll
It is to me.
Please cite the FAR that requires a charted PT to be flown whenever one of
the prohibitions of FAR 91.175(j) is not applicable.
Steve,
do
the same.
Nov. 28, 1994
535 Herndon Parkway
Herndon, VA 22070
Dear Mr. Young,
Sincerely,
/s/
Patricia R. Lane
for Donald P. Byrne
PART 97-STANDARD INSTRUMENT APPROACH PROCEDURES
Subpart C-TERPS Procedures
§ 97.20 General.
criteria.
by the FAA are documented on FAA Forms 8260-3, 8260-4, 8260-5. Weather
takeoff minimums are documented on FAA Form 8260-15A. These forms are
51...
I am aware of that interpretation, I am also aware that is NOT an
interpretation supported by the FARs.
Old October 6th 05, 02:06 AM
Ron Rosenfeld
On Mon, 03 Oct 2005 09:32:39 GMT, "Steven P. McNicoll"
No, that's your interpretation. I assume it is based on YOUR reading of
14 CFR 91, 14 CFR 97, 8260.3 as well as the textual description of the
various SIAP's published by the FAA.
My reading of those parts, along with other documents, leads me to disagree
with your interpretation.
In instances where it is clear, unambigous, and supported by others whose
business it is to intepret these things correctly (i.e. Jepp), I choose to
rely on the interpretation of the FAA regulatory division counsel, in
deciding what is required by regulations. And I would recommend others do
so, too.
Old October 6th 05, 05:37 PM
Steven P. McNicoll
disagree with your interpretation.
So make your case. Fill in the steps between "In the case of a radar vector
to a final approach course or fix, a timed approach from a holding fix, or
an approach for which the procedure specifies 'No PT,' no pilot may make a
procedure turn unless cleared to do so by ATC.[FAR 91.175(j)]", "Procedure
turn means the maneuver prescribed when it is necessary to reverse direction
to establish the aircraft on an intermediate or final approach course. The
outbound course, direction of turn, distance within which the turn must be
completed, and minimum altitude are specified in the procedure. However, the
point at which the turn may be commenced, and the type and rate of turn, is
left to the discretion of the pilot. [FAR 97.3(p)]", and, "If a SIAP does
contain a procedure turn and ATC has cleared a pilot to execute the SIAP,
the pilot must make the procedure turn when one of the conditions of Section
91.175(j) is not present.", [statement of Patricia R. Lane].
so, too.
I prefer logic. If it was clear and unambiguous this issue would never be
discussed here.
Old October 6th 05, 09:32 PM
Ron Rosenfeld
On Thu, 06 Oct 2005 16:37:34 GMT, "Steven P. McNicoll"
So make your case
I've already made my case. You may reread it and the references until you
understand it, or choose to disagree.
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
