manofsan,
Differential rotor speeds -will- rotate the aircraft, but will that turn the aircraft, in level flight, or just rotate the aircraft in yaw? The hard part about differential rotor speeds is not in yawing the aircraft. The hard part is NOT yawing the aircraft, constantly. Gyros might do the job of balancing rotor speeds for you (with *more* expense and complexity), but you would still lose the safety advantages of simplicity, and maintaining control if one motor fails. The spider gears and one motor might not maintain altitude, but you could still move forward and steer as you descend slowly, to select a good place for the BRS deployment. In a deployment situation, one motor could still be used for a last-minute burst of power, to soften the parachute landing. Recovering energy by auto-rotation would mean a lot of weight and complexity for very small gains. Aircraft are like boats, always fighting drag, and if aircraft could get anything back on descent, they would have to expend a lot more energy to do the climb, first. You can never win against drag, so at best, we just try to cut our losses, up front. I hear Boeing is working on a single-engine plane using a fuel cell and an electric motor to provide propellor thrust, so that technology seems realistic. New hydrogen storage systems can derive their hydrogen "fuel" from other liquids, rather than highly pressurized hydrogen gas, which would need strong and heavy tanks. The WaveCrest motor idea looks good, too. -- (Replies *will* bounce, unless you delete the letter A from my email address) Cheers, Red wrote: Hi red, thanks for the great ideas. ![]() Hmm, I read about how a coax design can use differential rotation speed between the 2 rotors for the purpose of turning the aircraft. That'd be pretty easy to do with a wheelmotor for each rotor. Here's a link to a new kind of wheelmotor which is attracting attention: http://www.wavecrestlabs.com The company is headed by General Wesley Clark, former NATO commander. Regarding portable fuel cell for propulsion, here's another link: http://www.intelligent-energy.com/in...6&artID=3 709 And hydrogen is a lightweight fuel too, for lower fuel load. But suppose you want some extra juice sometimes, for more maneuvering/lifting power. Then use the new Toshiba battery: http://www.dpreview.com/news/0503/05...sh1minbatt.asp It can apparently discharge and absorb energy at a very high rate. This might be useful for using regenerative braking to recover energy from your rotor when you're reducing airspeed/altitude, since a wheelmotor can convert torque/rpm back into electricity. Once you've landed, regenerative braking would allow you to quickly bring the rotors to a stop while recovering energy from them. I'd also imagine the electric motors would be quieter too, so your eardrums don't take a beating. |
Here is yet another interesting design from that same website:
http://www.gizmag.com/go/3107/ I wonder if this could be converted into a gyroplane? Here's how I imagine it. sorry, my ascii art isn't good enough to reproduce the chassis, so I just drew the tires (which of course have the electric wheelmotors in them): ========== | | ( o----------------+ ======== | | =========== Note that the "o-------------+" is supposed to be the rotor mast folded back along the longitudinal axis of the craft. Okay, I guess that would require the craft to have some kind of upper fuselage canopy for the mast to attach to. The "o" is the base of the mast which attaches to the upper fuselage canopy, while the "+" is where the rotor head would be. But the rotor mast wouldn't have to be very long, since it doesn't need much height for its rotors to clear the rest of the craft. The rotors themselves would be bent forward in V-shape from the rotorhead, with their tips clipped to the sides of the fuselage/chassis. So the wheelmotors roll the craft along the ground until it picks up lots of speed. Then the rotor mast pops upright, the rotors are freed and start spinning overhead. The craft then takes off like a gyroplane, and once airborn the front tires swivel to face frontwards to act as fan-props: || ||____ || | || | ( + ======= || | ||___|__ || || Heh, very James Bond-ish, huh? ;P |
Light Electric Rotorcraft | [email protected] | Home Built | 21 | October 6th 05 02:58 AM |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
OT but very funny after some of the posts we have had of late. | Mycroft | Military Aviation | 1 | August 8th 03 10:09 PM |
Electric whine in the light circuit - Help | Victor J. Osborne, Jr. | Owning | 1 | July 29th 03 11:36 PM |
