At 14:00 30 September 2005, Jmarc99 wrote:
It seams that everybody miss the right question in this thread.. What is the right airspeed to decide to get, when the wind is NOT perfectly alligned with the runway? When you have 15 knots wind, with gusts at 20... at 0 degree with the runway , you'll calculate 1.3 Vs + 15, right ? at 45 degree ... calculate 1.3 Vs + 15, right.. maybe ? at 90 degree ... calculate 1.3 Vs + 15, right.. no ? at 135 degree ... calculate 1.3 Vs + 15, no.. right.. maybe ? at 180 degree (wind right from the back) ... calculate 1.3 Vs + 15, always? or 1.3 Vs + 20 knots at all times, whatever the wind direction with the runway ? Or only 1.3 Vs when the wind will be at the back during the final ? The questtion is.. WHAT IS THE CALCULATED SPEED do you wish to get during the base and final, according with the wind angle with the runway. Do you take care the gusts speed or not in your calculation ? Is anyone can answer that simple question? jmarc.. Given that the above calculation is made with regard to the surface wind and that as far as the glider is concerned until it touches down the direction of the surface wind is of no consequence to the aircraft (the relative airflow experienced by a flying glider has no connection to the wind direction) I fail to see why the question is being asked. The simple answer is you have made the calculation based on the windspeed. Why do you need to worry about your groundspeed once you have touched down? |
![]() "Don Johnstone" wrote in message ... ... Given that the above calculation is made with regard to the surface wind and that as far as the glider is concerned until it touches down the direction of the surface wind is of no consequence to the aircraft (the relative airflow experienced by a flying glider has no connection to the wind direction) I fail to see why the question is being asked. The simple answer is you have made the calculation based on the windspeed. Why do you need to worry about your groundspeed once you have touched down? Hi Don, Indeed, the real concern is not about groundspeed...! It's about the right flying speed to get on the final leg, depending to the wind direction. The rule to calculate the airspeed is to increase it if the wind direction is facing the aircraft, but the rule seams to say that we shouldn't add anyting when the wind come the back. Sure, we would not substract anyting to1.3 Vstall in this case. Should we add the same amount of knots to 1.3 Vstall, regardless of the wind direction for every circuit legs? |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
A new direction for an old thread: Crosswind landings | [email protected] | Soaring | 96 | March 4th 05 01:22 AM |
Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 12:08 AM |
Strong crosswind landings! | Toks Desalu | Piloting | 12 | April 19th 04 07:43 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
