Clear to intercept localizer
Old October 6th 05, 09:58 AM
David Cartwright
"Newps" wrote in message
ATC is required to put you in a position to intercept the glideslope from
below.
By a strange coincidence, I was reading a recent CHIRP publication this
morning, and this very subject came up. The response, if I'm understanding
it correctly, is a little concerning - it implies that there are places
where a glideslope intercept from above is regarded as normal.
The text of the report is reproduced here.
Report Text
On several occasions at AAA (UK major airport), I have been vectored to the
ILS, on both the easterly and westerly runways, such that the aircraft is
above the glidepath at localiser intercept.
I have discovered that this is not an unknown occurrence; colleagues within
my Company and from other airlines have suffered similar problems. I
understand that representations have been made to the Duty Supervisor, but
the practice continues sporadically.
As far as I am aware, no aircraft are equipped to intercept the glidepath
automatically from above.
My next course of action will be an MOR, but CHIRP might just highlight the
issue such that an MOR is unnecessary.
CHIRP Comment
It is sometimes the case that height restrictions associated with airspace
structure or particular traffic conditions can result in intercepting the
localiser above the glidepath.
Also, the use of Continuous Descent Approaches (CDAs), required by the
Department for Transport for environmental reasons at some UK airports, is
also considered to be 'best practice' at other locations for the reduction
of noise, nuisance and emissions (UKAIP ENR 1-1-3-1 Para 2.3.1 refers).
One of the principal objectives of CDAs is for an aircraft to join the
glidepath without recourse to level flight. Where the use of CDAs are
promulgated in the appropriate AIP AD2 Section, the detailed procedure
permits the pilot to descend at a rate he judges will be best suited to the
achievement of continuous descent and thus avoid the problem described in
this report. However, no standard RTF phraseology currently exists to cover
CDA procedures and it is not clear that pilots are always aware when a CDA
procedure is being conducted. In view of the important environmental
contribution of CDAs; it would be perhaps appropriate to review this
particular aspect.
If you are positioned significantly above the glidepath at localiser
intercept, submit an MOR to permit the reasons to be investigated.
Regards,
David C
Old October 6th 05, 05:53 PM
Steven P. McNicoll
"David Cartwright" wrote in message
What is CHIRP? In the US, ATC is required to vector aircraft to intercept
the localizer at an altitude not above the glideslope or below the minimum
glideslope intercept altitude specified on the SIAP.
Old October 7th 05, 09:18 AM
David Cartwright
link.net...
The Confidential Human factors Incident Reporting Programme - a way for UK
pilots to report "negative" human factors-induced events that either (a)
aren't necessarily formally reportable or (b) they would rather raise
anonymously rather than complain to their company, for fear of reprisals.
Summaries are produced quarterly, and are seen to be very valuable to the
aviation community, and where appropriate the relevant authorities are
consulted/informed in order that action may be considered, without
compromising confidentiality. Have a look at http://www.chirp.co.uk/.
Cheers,
D.
Old October 6th 05, 08:06 PM
John R. Copeland
"David Cartwright" wrote in message =
=20
=20
As far as I am aware, no aircraft are equipped to intercept the =
glidepath=20
=20
David C
It strains my FAA-trained imagination even to call that a "glidepath =
intercept".
Localizer front/back course and reverse sensing Mark Hansen Instrument Flight Rules 10 September 11th 05 04:39 PM
when does a "remain clear" instruction end? Arden Prinz Piloting 171 March 2nd 04 12:26 AM
Vectored past the localizer Doug Instrument Flight Rules 28 December 30th 03 07:05 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Localizer Back Course vs. ILS ilsub Instrument Flight Rules 8 August 25th 03 04:04 PM
