The Instrument you can live without
Old October 6th 05, 02:29 AM
George Patterson
vincent p. norris wrote:
A couple of years ago,a high-time pilot who, according to reports,
emphasized partial panel work, took off from TEB and soon killed
himself and family in a Bonanza. Apparently a gyro failure.
The only Bonanza accident at TEB that I remember in the last 5 years or so
involved a doctor who was taking proscribed medication and had been for some
time. After the failure, he couldn't seem to follow ATC's instructions -- just
kept repeating that he was in trouble. Wound up putting it into an urban area
and killing a few people on the ground.
If that's the one you're thinking of, it wouldn't be a good case for arguing a
stand on any partial panel situation. Seems to me the most important instrument
that failed was the pilot's brain, and that had been running on partial panel
for years.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 6th 05, 04:22 AM
cjcampbell
Chris W wrote:
If you were about to go on an IFR flight, and for some unknown,
hypothetical reason you had to pick one instrument in the standard six
pack that you could not use, which one would it be?
You do err, for as the CFI-I, I am the one who gets to pick which of
those instruments it will be, and I am liable to pick more than one of
them. BWOOWOOHAHAHAHAHAA!
Old October 6th 05, 04:09 PM
Mark T. Dame
Have you any words of explanation to offer, or do you know what the
accident report said?
The problem with a gyro failure isn't flying the plane without your gyro
instruments, but recognizing the failure in the first place. I would
guess that most crashes caused by failed gyros were because the pilot
didn't recognize the failure.
A failed gyro can be very difficult to detect. I've done it in a
simulator and didn't notice for a several minutes. For people who focus
too much on the AI, it's especially bad because they can end up putting
the plane in an unusual attitude very quickly.
-m
## Mark T. Dame
## VP, Product Development
## MFM Software, Inc. (http://www.mfm.com/)
"Outside of the killings, Washington has one of the lowest crime
rates in the country."
-- Marion Barry, Mayor, Washington, D.C.
Old October 6th 05, 07:04 PM
I practice partial panel regularly, but accidents like that worry me;
if that guy couldn't hack it, could I?
The problem here is the same as with the "are twins safer?" debate: we
don't hear about the partial-panel flights that *don't* crash. You will
find single incidents of very experienced pilots making every mistake
in the book.
-cwk.
Old October 6th 05, 09:39 PM
Matt Whiting
I began teaching what I call
"Primitive Panel" over 30 years ago with a loss of gyros, then taking
away the Turn/Slip, the VSI, and leaving the student with little to
work with. They can do fine if they use their heads.
That is the main flaw with partial panel practice. You know the gyro
has failed. In a real failure, you may well not notice the failure
until it is too late. That is one reason why my Skylane had a low
vacuum light and a PF standby system.
Matt
Old October 6th 05, 09:48 PM
Stefan
You will know it pretty eimdiately, *if* you are not too lazy to
permanently do the cross checks. Cross check possibility is the reason
why you have all those "useless" instruments like VSI and turn coordinator.
Stefan
Old October 6th 05, 09:58 PM
Matt Whiting
OK, you obviously have no, or very little, experience flying single
pilot IFR. There are times when things get very busy and the cross
checks don't occur at nearly the frequency you might desire. And subtle
failures can be hard to detect in the early stages.
Matt
Old October 6th 05, 10:14 PM
Stefan
Little. Anyway, if you can't do the cross checks, then you're not safe.
If single pilot IFR means that the workload is too high to regularly do
the cross checks, then it's debatable whether single pilot IFR in IMC
should be allowed at all.
Stefan
Old October 7th 05, 12:21 AM
LWG
That's why I really like practicing IFR with MS Flight Sim. I set the
instruments to fail randomly. The first few times the AI failed, I did tend
to follow the dead AI as it keeled over. I think it really improves your
scan. It just isn't the same when the CFII slaps a plastic disc over it and
says "You've just lost your AI." A good portion of the lesson was lost
already at that point.
" That is the main flaw with partial panel practice. You know the gyro
has failed. In a real failure, you may well not notice the failure until
it is too late.
Old October 7th 05, 12:31 AM
Matt Whiting
You can do cross checks, just not every 20 seconds, and maybe not every
60 seconds during certain phases of the flight. You prioritize your
tasks based on needs to be done and the probability that something will
go wrong. Losing the vacuum or losing oil pressure or having all of the
fuel leak out are low probability events so you don't check them every
10 seconds. You need to check your heading and altitude very frequently
when nearing the MDA or DH on an approach, but you don't check nearly as
frequently during cruise.
You have the typical attitude of someone who has read about instrument
flying, but hasn't done any.
Matt
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
